FME Transformers: 2025.0
ArcGISAttachmentConnector
Connects to an ArcGIS Feature Service to manage attachments. Supports adding, updating, deleting, listing, and downloading attachments.
- Attaching images, PDFs, or other files to ArcGIS Feature Service features
- Updating or deleting existing attachments
- Listing attachment metadata for validation or logging
- Downloading attachments for local storage or further processing
The ArcGISAttachmentConnector connects to an ArcGIS Feature Service to add, update, delete, list, or download attachments.
- Note that when accessing branch versioned feature services, the ArcGISAttachmentConnector will only download or modify attachments on the default branch of the feature service. See ArcGISBranchVersionManager.
The output of this transformer will vary depending on the Action performed. Attachment metadata and operation results are presented as feature attributes.
- After an Add action: Output features represent successfully uploaded attachments with relevant IDs.
- After a Delete action: Output features confirm the removal of specified attachments.
- After a Download action: Output features contain the downloaded attachment data.
- After a List action: Output features represent the metadata of the attachments linked to a feature. Each output feature corresponds to a single attachment.
- After an Update action: Output features represent updated attachments with confirmation attributes.
The incoming feature is output through this port.
Features that cause the operation to fail are output through this port. An fme_rejection_code attribute describing the category of the error will be added, along with a more descriptive fme_rejection_message attribute which contains more specific details as to the reason for the failure.
Connection |
To create an ArcGIS connection, click the ArcGIS Connection drop-down box and select Add Web Connection.... The connection can then be managed via Tools > FME Options > Web Connections. |
Action |
The type of operation to perform. Choices include:
Feature
Feature URL |
URL to the feature where attachment operations will be performed. Follows this form: https://<feature_service_url>/<layer_id>/<object_id_of_feature> Esri ArcGIS Feature Service reader returns the feature URL in a format attribute, arcgisfeatureservice_feature_url, which may be used for the Feature URL. Using GlobalIDs for ArcGIS Feature Service Attachments ArcGIS REST endpoints always require an OBJECTID in the path—there’s no built-in way to use a GlobalID directly. Without an OBJECTID, attachment operations are not supported. |
Data Source
Upload |
Specify whether uploading from a file or a feature attribute. |
File to Add |
The file path containing the content to be uploaded if ‘Upload’ is ‘File’. |
Attribute to Add as File |
The attribute from which you want the content to be uploaded if ‘Upload’ is ‘Attribute’. |
Metadata
Keywords |
(Optional) Keywords for the attachment (if enabled in the feature service settings). |
Add with Filename |
The name of the uploaded file including the extension (i.e. file.txt) if ‘Upload’ is ‘Attribute’. |
Added Attributes
These attributes will be added to the output features:
_attachment_id |
The Object ID of the newly added attachment. |
_global_id |
The global ID of the newly added attachment. |
Request
Delete All Feature Attachments |
Whether or not to delete all existing attachments for the feature. |
Feature
Feature URL |
Attachment ID |
The ID of the attachment on which operations will be performed. |
Added Attributes
_attachment_id |
The Object ID of the deleted attachment. This attribute is only outputted if the “Delete all for Feature” option is set to “No” |
_total_attachments |
Total number of attachments on the feature. This attribute is only outputted if the “Delete all for Feature” option is set to “Yes” |
_attachments_deleted |
Total number of attachments deleted. This attribute is only outputted if the “Delete all for Feature” option is set to “Yes” |
_attachment_ids |
List of deleted attachments. This attribute is only outputted if the “Delete all for Feature” option is set to “Yes” |
_deletion_errors |
List of attachments that were not deleted successfully alongside their respective errors. This attribute is only outputted if the “Delete all for Feature” option is set to “Yes” |
Feature
Feature URL |
Attachment ID |
Destination
Download as |
Select whether to store the downloaded data in a File, Folder or Attribute.
Download to Folder |
When Download as is File, specify the path to the folder that will store the attachment. |
If File Exists |
When Download as is File, whether to overwrite existing files in the target destination. |
Download to Attribute |
When Download as is Attribute, specify the attribute that will store the attachment. |
Added Attributes
_downloaded_path |
The local path where the downloaded attachment is saved (if attachment is saved to a file). |
_filename |
The actual filename of the downloaded file. |
_file_size |
The size of the downloaded file in bytes. |
_content_type |
The MIME type of the downloaded file. |
Feature
Feature URL |
Output Attributes
Attributes to Add |
Select any available attributes to be included on the output features:
Feature
Feature URL |
Attachment ID |
Data Source
Upload |
File to Add |
Metadata
Keywords |
Add with Filename |
Added Attributes
This attribute will be added to the output features:
_attachment_id |
The Object ID of the updated attachment. |
| Dependencies | Esri Access |
Search for all results about the ArcGISAttachmentConnector on the FME Community.
