FME Flow: 2025.0
Removing Jobs
Removing Selected Jobs
To remove one or more jobs, select the job entries in the desired table, and click Remove (Completed) or Cancel (Queued or Running).
Note Before jobs are removed from the Running table, the FME Engine stops processing them.
Removing All Jobs
To remove all jobs in a job table at once, click Remove All (Completed) or Cancel All (Queued or Running).
Removing Completed Jobs Older Than a Specified Time Period
On the System Cleanup page, you can create a task to run on an ongoing basis that removes jobs from the Completed table that are older than a specified time period. For more information, see Scheduled Cleanups.
