FME Transformers: 2024.2
BoundingBoxAccumulator
Determining the extents of an entire set of features
The BoundingBoxAccumulator receives features with any geometry type and creates the minimum enclosing rectangular polygon that contains all features. The rectangle is not rotated. Its sides are parallel to the x and y axes.
If features are 3D, including point clouds, the bounding box will contain their footprint - that is, their x and y extents.
If an output bounding box has zero area (the bounding box of a single point or vertical line, for example), it will become a point or line as appropriate.
The output bounding box can retain attributes from the input features, either as a single set of attribute values or a list of values from all input features.
In this example, we have a set of rapid transit lines and want to generate the bounding box that contains all features.
Note that they have an attribute containing the name of the line.
The features are routed into a BoundingBoxAccumulator.
In the parameters dialog, we enable Generate List to add a list attribute to the output bounding box. It is named Lines and will contain the LINE value from all input features.
One bounding box is produced, spanning all input features. Note the list attribute containing the LINE values.
Creating and Modifying Boxes and Rectangles
Creating rectangular geometry is a common task. These transformers do so in a variety of ways.
Transformer |
Use this to... |
Transformer Description |
Create one or more new features with box geometry of a specific size and position (when Geometry Object is Box). |
Replace an existing feature’s geometry with a box of a specific size and position. |
Replaces feature geometry with a 2D box defined by specified minimum and maximum x and y values. |
Create one rectangle that encompasses all features received. |
Creates a rectangular polygon that spans the extents of all input features. |
Individually replace the geometry of each feature with a rectangle that covers its extents. |
Replaces feature geometry with a box or cube that spans the extents of the feature. |
Individually replace the geometry of each raster feature with a rectangle. |
Extract the coordinate values that describe an individual feature’s bounding box (or cube) and store them as attributes. |
Extracts a feature’s minimum and maximum coordinate values into attributes. |
Create a series of regularly-spaced rectangles that span the extent of all features (when Type of Grid to Create is Polygons). |
Create a series of regularly-spaced rectangles of a specific size and position (when Type of Grid to Create is Polygons). |
Tiler and RasterTiler |
Chop features into a series of rectangular tiles, specified in a similar fashion to the 2DGridAccumulator. |
Splits input features into a series of tiles by specifying either tile size (in ground units) or total number of tiles. Splits each input raster into a series of tiles by specifying either a tile size in cells/pixels or the number of tiles. |
Features with geometry.
A rectangle spanning the extent of all input features, optionally with attributes as specified in parameters.
Features without valid geometry are output via this port.
INVALID_GEOMETRY_VERTICES
Group By |
The input features may be partitioned into groups based on attribute values. One bounding box is output for each group. If Group By is not specified, all input features will be processed together and a single bounding box will be output. |
Complete Groups
Accumulation Mode |
Drop Incoming Attributes: The bounding box receives no attributes. Merge Incoming Attributes: The bounding box receives all attributes from input features. Use Attributes From One Feature: The bounding box receives all attributes from one representative feature. |
Generate List |
When enabled, adds a list attribute to the output bounding box with values from multiple input features.
Note List attributes are not accessible from the output schema in FME Workbench unless they are first processed using a transformer that operates on them, such as ListExploder or ListConcatenator. Alternatively, AttributeExposer can be used.
Yes |
Dependencies |
None |
Aliases |
History |
Search for all results about the BoundingBoxAccumulator on the FME Community.
