FME Transformers: 2024.2
2DBoxReplacer
Replaces feature geometry with a 2D box defined by specified minimum and maximum x and y values.
Creating search envelopes
Creating clip boundaries
The 2DBoxReplacer receives features of any kind and replaces their geometry with 2D boxes as specified in parameters.
The parameters describe rectangular geometry with minimum and maximum x and y values, representing the box's lower left and upper right corners, in the ground units of the feature’s coordinate system.
Values may be entered directly or provided via attributes, parameters, or expressions.
In this example, we have a point dataset of food cart vendors. We want to replace the points with boxes centered on the point locations.
Note that the features have a UTM coordinate system, with ground units in meters.
The features are routed into a 2DBoxReplacer.
In the parameters dialog, expressions are created to offset the corners by 50 meters from the point location.
The points have been replaced with boxes.
Creating and Modifying Boxes and Rectangles
Creating rectangular geometry is a common task. These transformers do so in a variety of ways.
Transformer |
Use this to... |
Transformer Description |
Create one or more new features with box geometry of a specific size and position (when Geometry Object is Box). |
Replace an existing feature’s geometry with a box of a specific size and position. |
Replaces feature geometry with a 2D box defined by specified minimum and maximum x and y values. |
Create one rectangle that encompasses all features received. |
Creates a rectangular polygon that spans the extents of all input features. |
Individually replace the geometry of each feature with a rectangle that covers its extents. |
Replaces feature geometry with a box or cube that spans the extents of the feature. |
Individually replace the geometry of each raster feature with a rectangle. |
Extract the coordinate values that describe an individual feature’s bounding box (or cube) and store them as attributes. |
Extracts a feature’s minimum and maximum coordinate values into attributes. |
Create a series of regularly-spaced rectangles that span the extent of all features (when Type of Grid to Create is Polygons). |
Create a series of regularly-spaced rectangles of a specific size and position (when Type of Grid to Create is Polygons). |
Tiler and RasterTiler |
Chop features into a series of rectangular tiles, specified in a similar fashion to the 2DGridAccumulator. |
Splits input features into a series of tiles by specifying either tile size (in ground units) or total number of tiles. Splits each input raster into a series of tiles by specifying either a tile size in cells/pixels or the number of tiles. |
The dynamic <Rejected> port appears when a parameter is set to a non-literal value that might make processing impossible.
For example, if a numeric parameter such as Line Width, Count Start, or Decimal Places is set to an expression, attribute value, or user parameter, it is possible to pass in a non-numeric value that cannot be used. Decimal Places = Cat cannot be processed, so the feature will be output via this port.
Rejected features will have an fme_rejection_code attribute explaining the reason for rejection.
Min X Value |
Specify the minimum x value (lower left) of the box. |
Min Y Value |
Specify the minimum y value (lower left) of the box. |
Max X Value |
Specify the maximum x value (upper right) of the box. |
Max Y Value |
Specify the maximum y value (upper right) of the box. |
Search for all results about the 2DBoxReplacer on the FME Community.
