Managing Security Tokens
Select the User Settings icon > Manage Token.
Access to FME Flow is controlled through security tokens. Use the Token Management page to work with security tokens in the following ways:
- API Tokens: For development purposes, you can create and manage tokens that allow unauthenticated access to FME Flow.
- Session Tokens: Session tokens are created automatically when you log on to FME Flow.
- All Tokens: Users with Manage permission in User Management can view and manage the tokens of all users.
Working with API Tokens
To get started, select the API Tokens tab.
To Create an API Token
- Click New or, to duplicate an existing token, select it and click Actions > Duplicate.
- On the Create (or Duplicating) API Token page, specify a token Name, Description (optional), Expiration, and Enabled status.
- To grant the user of the token all permissions of the current user, slide the All Permissions control to the right. Otherwise, configure the permissions as desired.
Warning To guarantee the security of the FME Flow, ensure a token's permissions are configured so that it can be used only for its intended purpose, such as running a particular workspace.
About permissions in FME Flow
Automations
| Access |
Access the Automations page, and list workflows and tags. |
fmeadmin, fmeauthor, fmesuperuser |
| Create |
Create automations. |
Individual Automations:
- Read: View a workflow and its log file.
- Write: Edit or remove a workflow.
- Run: Start and stop a workflow.
- Apps: Run a workflow through an automation app.
- Webhooks: Access a URL generated by a Webhook trigger that requires authentication.
Note Automations requires additional permissions. You are prompted to grant any additional permissions that are required.
Connections
| Access |
Access the Database Connections and Web Connections pages. |
| Create |
Create connections. |
| Manage |
Access, create, and remove connections. |
Individual Connections:
- Access: Manage web services.
Deployment Parameters
| Access |
Access the Deployment Parameter Store. |
| Create |
Create deployment parameters. |
Individual deployment parameters:
- Read: Access a deployment parameter.
- Write: Edit a deployment parameter.
- Remove: Remove a deployment parameter.
Flow Automation Apps
| Access |
Access the Automation Apps page. |
| Create |
Create automation apps. |
Individual Automation Apps:
- Run: Run an automation app.
- Read: Access an automation app.
- Write: Edit or remove an automation app.
Flow Gallery Apps
| Access |
Access the Gallery Apps page |
| Create |
Create gallery apps. |
Individual Gallery Apps:
- Run: Open links in a gallery app.
- Read: Access a gallery app.
- Write: Edit or remove a gallery app.
Flow Workspace Apps
| Access |
Access the Workspace Apps page. |
| Create |
Create workspace apps. |
Individual Workspace Apps:
- Run: Run a workspace app.
- Read: Access a workspace app.
- Write: Edit or remove a workspace app.
Jobs
| Access |
Access the Jobs page to view the jobs you have run, or cancel any of your jobs that are currently running or in queue. |
fmeadmin, fmeauthor, fmeguest, fmesuperuser, fmeuser |
| Manage |
Access and manage the jobs of all users. You can:- Cancel any job that is currently running.
- Remove the history of jobs that were previously run.
fmeadmin, fmesuperuser |
Packages
| Access |
Add FME packages to Projects. |
| Upload |
Publish FME packages from FME Form to FME Flow and remove existing packages. |
Projects
| Access |
Access the Projects page. |
| Create |
Create projects. |
Individual Projects:
- Read: View information about a project.
- Write: Edit a project.
- Delete: Delete a project, or delete items from a project.
Note Access or Create permission is not required to have Read/Write/Delete permission on individual projects. These tasks can still be accomplished with the
REST API.
Publications
| Access |
Access the Publications page. |
| Create |
Create Notification Service Publications. |
Individual Publications:
- Read: View information about a publication.
- Write: Edit a publication.
- Remove: Delete a publication.
Queue Control
| Manage |
Access to Queue Control, except engine assignment rules (also requires Manage permission in Licensing & Engines). |
Repositories
| Access |
Access the Workspaces page.Note Access permission is not required to run a workspace. Only Run permission on the applicable repository is required (see below). |
| Create |
Create repositories. |
Individual Repositories:
- Download: Download workspaces and other repository items from FME Flow into FME Workbench.
- Read: View repository information.
- Publish: Publish workspaces and other items to the repository from FME Workbench.
- Run: Run repository workspaces from FME Flow.
Note Users must also have Allow permission on the applicable service (see Services) when running workspaces.
- Remove: Remove a repository, or remove items from a repository.
Note You must uncheck all five permissions to completely remove a role from membership with a repository.
Resources
| Access |
Access the Resources page. |
| Create |
Create connections to network resources. |
Schedules
| Access |
Access the Schedules page. |
| Create |
Create schedules. |
Individual Schedules:
- Full Access: Edit or delete a schedule.
Services
| Manage |
Configure the FME Flow services. |
Individual Services:
- Full Access: Manage FME Flow services.
Streams
| Access |
Access the Streams page. |
| Create |
Create streams. |
Individual Streams:
- Read: View a stream.
- Write: Edit or remove a stream.
Subscriptions
| Access |
Access the Subscriptions page. |
| Create |
Create Notification Service Subscriptions. |
Individual Subscriptions:
- Read: View information about a subscription.
- Write: Edit a subscription.
- Remove: Delete a subscription.
Topics
| Access |
Access the Topics page. |
| Create |
Create topics. |
Individual Topics:
- Read: View information about a topic.
- Write: Edit a topic.
- Publish: Publish notifications to a topic.
- Remove: Delete a topic.
Version Control
| Access |
Commit versions and view repository history. |
| Manage |
Enable version control and configure with a remote Git repository. |
- Click OK.
- Click Download to save the token. After the token downloads, click OK.
To Remove, Enable, or Disable an API Token
Select the token and click Actions > Remove, Enable, or Disable.
Alternatively, to enable or disable a token, click on the token. On the Editing page, update the Enabled status, and click OK.
Working with Session Tokens
When you log in to the Web User Interface, FME Flow grants you a security token to use the Interface for a period of 30 minutes. However, FME Flow automatically extends this period if you remain logged in for more than 20 minutes and your browser window remains open. To view your token ID and expiration, select the Session Tokens tab.
To remove, disable, or enable an active session token, select it and click Actions > Remove, Disable, or Enable. To remove an expired token, select it and click Remove.
Note Expired session tokens cannot be enabled or disabled.
Working with All Tokens
Users with Manage permission in User Management can view and manage the tokens of all users. To view all user tokens, select the All Tokens tab. Under Filters, you can limit your view by token owner, type (API or Session), and status (Active or Expired).
To duplicate, remove, disable, or enable a token, select it and click Actions > Duplicate, Remove, Disable, or Enable.
If the token is an API token, you can click on it to view and edit its properties and permissions. For more information, see Working with API Tokens, above.
