FME Transformers: 2024.1
SurfaceDissolver
Detects coplanar regions of input surfaces and dissolves them into single faces. The output faces retain the attributes, traits, and appearances of the input.
All surfaces are broken down into faces. For example, a mesh is broken into faces, one face per mesh part. Non-surface input features are not supported.
Example:
Surface features.
Surface features are output here.
Non-surface features are output here.
Group By |
The default behavior is to use the entire set of features as the group. This option allows you to select attributes that define which groups to form. |
Complete Groups |
Dissolve Inputs Separately |
No: The transformer will operate in a blocking mode which collects all inputs and dissolves them together. Yes: The transformer will operate in a non-blocking mode which dissolves each input individually. The output geometry type in this mode will try to match the type of the input. Note that attribute accumulation will not be applied in this case because each feature is handled separately. |
Aggregate Handling |
Deaggregate: Aggregate geometries will be split and their parts will be handled individually. Reject: Aggregate geometries will be immediately rejected. |
Normal Tolerance (degrees) |
Faces must be coplanar before they are allowed to dissolve together. If two faces are nearly coplanar with normals that are slightly apart, use this parameter to set a tolerance in degrees. The larger the value, the less coplanar the faces would have to be while still considered coplanar to each other. |
Offset Tolerance |
Faces must be coplanar before they are allowed to dissolve together. If two faces are nearly coplanar, but are a small offset from each other, use this parameter to set a tolerance in ground units. The larger the value, the farther away the faces could be while still considered coplanar. |
Require Matching Appearances |
No: Faces which are within tolerance will be dissolved regardless of their appearances, the appearance for the output face will be chosen from one of the inputs. Yes: Faces which have different appearances will not be dissolved together. Side matters, so faces with the same front and back appearance will not be dissolved if they are oriented in different directions. |
Accumulation Mode |
Specifies how attributes should be accumulated. If Drop Incoming Attributes is selected, all incoming attributes are removed from the features. Merge Incoming Attributes merges all attributes from overlapping features. Use Attributes From One Feature takes all attributes from one representative feature. |
Generate List
When enabled, adds a list attribute to the output features, retaining attribute values for multiple input features. A list with the same name is created for traits.
List Name |
Enter a name for the list attribute. Note List attributes are not accessible from the output schema in FME Workbench unless they are first processed using a transformer that operates on them, such as ListExploder or ListConcatenator. Alternatively, AttributeExposer can be used.
Add To List |
All Attributes: Every attribute from all input features that contributed to the output feature will be added to the list specified in List Name. Selected Attributes: Only the attributes specified in the Selected Attributes parameter will be added to the list specified in List Name. |
Selected Attributes |
The attributes to be added to the list when Add To List is Selected Attributes. |
Dissolve Count |
The Dissolve Count Attribute is equal to 1 plus the number of faces which have been dissolved into another. This count will be 1 if the input is unchanged or greater than 1 if faces were dissolved. |
Search for all results about the SurfaceDissolver on the FME Community.
