FME Transformers: 2024.1
OffsetCurveGenerator
Creates offset parallel lines on either side of curve features.
- Creating parallel lines to the left, right, or both sides of a curve feature
The OffsetCurveGenerator takes in curve features and creates new curves on either side of the original. These new lines are placed at a specified Offset distance from the original, on the left and right-hand sides. There is a choice of how corners are created - round, mitered, or beveled.
The new offset curves are output as Right and Left, according to the orientation of the original feature.
Two options for Buffer Mode are available. Standard (Fast) can generalize the geometry, producing faster and simpler results. Precise honors the input.
In this example, we will create offset lines on either side of a rapid transit line. The original feature is a single curve.
The feature is routed into an OffsetCurveGenerator.
In the parameters dialog, we set the Offset to 100, which will create the new offset curves 100 meters away from the original feature (which is in a UTM projection, ground units in meters). The Corner Style chosen is Round.
Two new curves are output from the transformer - one on the left side of the original line (shown in green), and one on the right (shown in red).
In a scenario where only one side is needed (left or right), simply disregard the unneeded output port.
Offset curves will be built in 2D from curve features. Self intersecting curves are not supported, and may produce unpredictable results. Other types of geometry will be output through the <Rejected> port.
Each point in the output curve will be the specified offset, measured in ground units, away from the input linear geometry. The output ports Left and Right will produce offset curves on either side of the input geometry.
Features without curve geometry are output through this port along with an additional attribute, fme_rejection_code, to indicate the reason for rejection.
Offset |
This parameter, measures in ground units, specifies the distance by which the output curve is offset from the input curve. |
Corner Style |
As the diagrams below illustrate, the corner styles of the offset curves can be Round (default), Bevel (chopped), or Miter (pointed). If Miter is used, a limit must be specified using the Miter Limit parameter. If a corner is too pointed for the miter limit, the corner will instead be beveled. Round
Bevel
Miter
Interpolation Angle |
This parameter, measured in degrees, controls the smoothness of the stroked arcs in the output offset curve. As this parameter decreases in value, the smoothness of the arc connectors increases. The specified value must be between 0 and 90 degrees. |
Miter Limit |
Miter Limit This parameter controls how pointed a buffered corner can be before it is beveled. It is the highest value that the ratio of corner distance to offset is allowed to have before truncation occurs. A higher number allows for more extreme corner angles.
Miter Ratio = Corner distance / Offset
Buffer Mode |
Controls whether input geometries are simplified before buffering.
| Dependencies | |
| Aliases | BufferCurveGenerator |
Search for all results about the OffsetCurveGenerator on the FME Community.
