FME Transformers: 2024.1
GoogleLanguageConnector
Accesses the Google Natural Language and Google Cloud Translation API for text analysis, such as language and sentiment detection.
- Submit text to Google Natural Language to detect text sentiments
- Submit text to Google Cloud Translation to detect languages
The GoogleLanguageConnector uses your Google Cloud account credentials to access Google’s Natural Language and Cloud Translation services.
It will submit text to the respective services, and return features with attributes about that text. Each input text may result in several output features.
For more information, see Google’s documentation:
This transformer accepts text features.
Output will depend on the detection type. Each input feature may result in multiple output features. For example, a single text can contain multiple languages or sentiments.
Language Detection
Detects the language of a text.
Attributes
_language_code |
Supported language detection and language codes can be found here: https://cloud.google.com/translate/docs/languages If the language cannot be detected “und” (undetermined) will be returned. |
_confidence |
The confidence in language detection, a value between 0 and 1. |
_original_text |
The original text inputted. |
Sentiment Detection
Inspect the given text and identify the prevailing emotional opinion within the text, especially to determine a writer's attitude as positive, negative, or neutral.
Attributes
_sentiment_score |
The sentiment score ranges between -1.0 (negative) and 1.0 (positive) and corresponds to the overall emotional leaning of the text. |
_original_text |
The text submitted in the request. |
The incoming feature is output through this port.
Features that cause the operation to fail are output through this port. An fme_rejection_code attribute, having the value ERROR_DURING_PROCESSING, will be added, along with a more descriptive fme_rejection_message attribute which contains more specific details as to the reason for the failure.
Credential Source |
The GoogleLanguageConnector can use credentials from different sources. Using a Service Account File integrates best with FME, but in some cases, you may wish to use a web connection.
Account |
Available when the credential source is Web Connection. To create a Google Cloud AI connection, click the 'Account' drop-down box and select 'Add Web Connection...'. The connection can then be managed via Tools -> FME Options... -> Web Connections. |
Text |
The text to be analyzed. |
Detection Type |
The type of operation to perform. Choices are:
| Dependencies | Google Cloud Account with access to the Cloud Natural Language and Cloud Translation APIs |
| History | Released FME 2019.2 |
Search for all results about the GoogleLanguageConnector on the FME Community.
