FME Transformers: 2024.1
GoogleIoTConnector
Connects to the Google IoT Core. Supports sending (producing) and receiving (consuming) messages.
- Automatically predict when equipment needs maintenance, and track device status, state, and location
- Manage device data for use on Google IoT Core and other services
- Bring automation into entire homes, buildings or cities
The output of this transformer will vary depending on the action performed. Message data and metadata are presented as feature attributes.
- After a Subscribe action, output features represent messages received from Google IoT Core.
- After a Publish action, output features represent messages sent to Google IoT Core.
The incoming feature is output through this port.
Features that cause the operation to fail are output through this port. An fme_rejection_code attribute, having the value ERROR_DURING_PROCESSING, will be added, along with a more descriptive fme_rejection_message attribute which contains more specific details as to the reason for the failure.
Credential Source |
Using a web connection integrates best with FME, but in some cases, you may wish to use one of the other sources.
Account |
Available when the credential source is Web Connection. To create a Google IoT connection, click the 'Account' drop-down box and select 'Add Web Connection...'. The connection can then be managed via Tools -> FME Options... -> Web Connections. |
Project ID |
Available when the credential source is Embedded. The Google Cloud project ID. |
Client Private Key |
Available when the credential source is Embedded. Private key for device authentication. This can be generated with the instructions at https://cloud.google.com/iot/docs/how-tos/credentials/keys#generating_an_rsa_key. |
CA Certificate |
Google root CA certifications. This can be found at https://cloud.google.com/iot/docs/how-tos/mqtt-bridge#downloading_mqtt_server_certificates. |
Location |
The region of the IoT Core registry. This is selected when creating the IoT Core registry. |
Registry ID |
The unique registry identifier for the IoT Core registry. This is created when creating the IoT Core registry. |
Device ID |
The unique identifier for the device. This is created when creating a device on Google IoT Core. |
Action |
The type of operation to perform. Choices are:
QoS Level |
The MQTT protocol allows a Quality of Service (QoS) level to be set. The following levels are available:
The QoS guarantees are achieved by performing differing levels of client-server handshake. As a result, higher QoS levels are expected to lower throughput. |
The remaining parameters available depend on the value of the Request > Action parameter. Parameters for each Action are detailed below.
Send Options
Payload |
The content of the message. This is often JSON, but can be any string, binary, integer or floating-point value. |
Send Options
Payload |
Receive Options
Receive Mode |
Two message receiving options are available:
Batch Size |
In Batch mode, specifies the number of messages to read per batch. |
Receive Options
Receive Mode |
Batch Size |
The following attributes can be selected for inclusion on the output features. Each output feature represents a message that was either sent or received.
_message_id |
The sequential identifier for the message. |
_payload |
The message payload. UTF-8 string if possible to decode, otherwise binary or numeric. |
_topic |
The topic the message received from or sent to. |
_qos |
The quality of service level with which the message was sent or received. |
| Dependencies | |
| History | Released FME 2019.0 |
Search for all results about the GoogleIoTConnector on the FME Community.
