FME Transformers: 2024.1
GeometryPartExtractor
Extracts selected geometry parts based on a Geometry XQuery.
Input Port
Features with geometries.
Features with newly extracted geometry parts.
Original feature with selected parts removed.
Features that were not modified by the transformer.
Geometry XQuery |
Use this parameter to isolate only a portion of the input geometry. If no criteria are specified, the action will apply to the entire geometry at all levels. Selection can be based on structural location, geometry name, type, appearance information, traits, trait storage types, or definition reference. The syntax used is a restricted set of XQuery, where the return clause is fixed. The basic Geometry XQuery dialog allows you to construct simple selection queries by automatically writing the necessary query based on specified test clauses. Clicking the Switch to Advanced button opens the Advanced Editor, which allows you to type a query free-form, for more expressive queries. Note Once you switch to Advanced mode, you will have to clear all parameters before you can return to Basic mode.
A hierarchical geometry is represented as nodes of type geometry, with attributes containing information about traits, type, and name for each geometry. Note Unlike other transformers that contain the Geometry XQuery parameter, this transformer requires that you specify a Geometry XQuery. If
you want to extract every single part, one method is to use an XQuery that matches the "Hierarchy Position" to "Leaf Node". Alternatively, you can use a Deaggregator in hierarchy mode, which may produce more useful output.
Search for all results about the GeometryPartExtractor on the FME Community.
Keywords: GeometryPartRemover
