FME Transformers: 2024.1
ElevationExtractor
Extracts a feature’s first z coordinate value, storing it in an attribute.
Extracting elevations from geometry to an attribute for further processing.
The ElevationExtractor receives any type of geometry and extracts the z coordinate value of the feature’s first coordinate into an attribute.
If the input feature is 2D, the Elevation output attribute will receive a value of zero (0).
Rasters, including elevation models, will also receive an elevation value of zero (0).
In this example, we have a CAD file of 3D elevation points, and want to access the z values as an attribute.
The features are routed into an ElevationExtractor.
In the parameters dialog, the Elevation output attribute is left with its default name.
The output features have a new attribute containing the extracted values.
Features with an attribute containing elevation values.
Elevation |
Name the attribute to contain the elevation values. |
Search for all results about the ElevationExtractor on the FME Community.
