FME Transformers: 2024.1
DEMDistanceCalculator
Calculates the distance between a number of input vector lines and the elevation values of a reference DEM raster, and outputs a new DEM raster per input line.
The data contained in the resulting DEM consists of the 3D distance between the line being considered and the corresponding point on the reference DEM.
This transformer supports raster band and palette selection. The RasterSelector can be used to modify selection.
A reference DEM raster. Only the first raster feature received for each Group By grouping will be used.
3D line features.
Raster DEMs representing the 3D distance between a line and the corresponding point on the reference DEM.
Any input features entering the Line port that are not 3D lines will be rejected with the fme_rejection_code attribute set to INVALID_VECTOR_GEOMETRY_TYPE.
Any input features entering the RefDem port that are not valid DEM rasters will be rejected with the fme_rejection_code attribute set to INVALID_REF_RASTER_GEOMETRY.
If more than one DEM raster is received for a Group By grouping, the extra rasters will be rejected with the fme_rejection_code attribute set to EXTRA_REF_RASTER_FEATURE.
Group By |
Use this parameter to organize lines into groups, with each group of lines having its own reference DEM. |
Complete Groups |
Search for all results about the DEMDistanceCalculator on the FME Community.
Keywords: raster band palette vector distance DEM
