FME Transformers: 2024.1
CharacterCodeReplacer
Sets the result attribute to the character whose numeric code was contained in the source code attribute (or the entered integer).
This can be used when the numeric Unicode code of any character (from Basic Multilingual Plane) is available, but the actual Unicode character is desired. For example, if the source attribute had the value 65487 (U+FFCF), a half-width Hangul letter ᅬ character would be placed in the resulting string.
To obtain the numeric code equivalent of a character, use the CharacterCodeExtractor.
Unicode Character Code |
The numeric Unicode code of any character. |
Character String |
Name the attribute to contain the resulting value. |
Transformer History
This transformer was previously named CharacterEncoder.
Search for all results about the CharacterCodeReplacer on the FME Community.
Keywords: CharacterEncoder
