FME Form: 2024.1
Downloading from FME Flow
                                                     on the Start page or Toolbar. The Download from FME Flow dialog opens:
Tip  If you open the Translation Log, you can view connection and processing statistics while  connected to FME Flow.
                                                - FME Flow Connection: Specify the connection for the FME Flow from which you want to download. For more information, see Connecting to FME Flow.
- Repository Name: The name of the repository that contains the item to download. Workspaces, custom formats and custom transformers are stored in specific folders (called "repositories") on FME Flow. Select a repository from the pull-down list.
- Selected Item Name:The name of the workspace, custom transformer, or custom format to download (selected below).
- Repository Browser: The items that are currently stored in the repository. Select an item to download.
- Download data files, if present: If the workspace, custom transformer, or custom format has file resources that also need to be downloaded, check this box.
Click Download. You are prompted to save the files to a local folder.
