TextureCoordinateSetter
                                            Assigns texture coordinates to surfaces.
- This transformer works only with surfaces, not including triangle strips and triangle fans.
 - Multi-surfaces are not yet supported.
        Texture Mapping Type  |
        If you choose Surface Normal, then the texture coordinates are assigned to the sloped surfaces. For composite surfaces, each surface will be treated separately since the parts can have different slopes. If you choose From Top View, the texture coordinates are assigned to the surfaces as if the surfaces are flat on the ground (that is, only X and Y coordinates are considered). In this mode, a composite surface is considered as one single geometry when the texture coordinates are applied.  |
        Width Scale Factor Height Scale Factor  |
        Use these parameters to specify the number of times the texture is repeated in rows and columns, respectively.  |
        Horizontal Offset and Vertical Offset  |
        Use these parameters to specify horizontal and vertical offset.  |
        Special Characters  |
Dialog Options - Tables
 Cut, copy, and paste may be used within a transformer, or between transformers.  |
        Generally resets the table to its initial state, and may provide additional options to remove invalid entries. Behavior varies between transformers.  |
Search for all results about the TextureCoordinateSetter on the FME Community.
