StringLengthCalculator
                                            Calculates the length of strings and the number of bytes in a blob.
Example
To calculate the number of bytes in a blob:
- Add a raster format reader (for example, TIFF).
 - Connect a RasterExtractor followed by a StringLengthCalculator.
 - In the StringLengthCalculator parameters, select _rasterBlob as the Source Attribute.
 - Connect an Inspector transformer.
 - Run the workspace.
Locate the _length attribute name in the Information Window:
Note that in non-ASCII character sets, the length is the number of actual characters (some or all of which could be multi-byte) in the string, which may not match the number of bytes used to store the string.
        Source Attribute  |
        After connecting the transformer, select the source attribute from the list.  |
        String Length Attribute  |
        This attribute contains the resulting value.  |
        Special Characters  |
Dialog Options - Tables
 Cut, copy, and paste may be used within a transformer, or between transformers.  |
        Generally resets the table to its initial state, and may provide additional options to remove invalid entries. Behavior varies between transformers.  |
Search for all results about the StringLengthCalculator on the FME Community.
