Reprojector
- Performing simple reprojections, without z value handling.
The Reprojector receives vector, raster, or point cloud features and reprojects their x and y coordinates from one coordinate system to another, generally using the FME (CS-Map) library.
This transformer will honor the Workspace Parameter Reprojection Engine, and will use the Esri Reprojection Engine if it is selected there, with or without an Esri product being installed.
The Source Coordinate System may be either read from the input feature or specified explicitly, and the Destination Coordinate System must be specified. Both may be set by selecting from the Coordinate System Gallery or by name via an attribute value or user parameter.
The Reprojector does not reproject z values.
Dynamic Coordinate Systems
Features may be reprojected to a dynamic Destination Coordinate System - that is, a local coordinate system that is created specifically for each individual feature. This is often used for tasks such as taking measurements or creating geometry in meters or other ground units, on data with geographic (latitude and longitude) coordinates.
There are two types available:
- _AZMEA_ (Dynamic Reprojection Equal Area) - Better for preserving area accuracy
 - _AZMED_ (Dynamic Reprojection Equal Distance) - Better for preserving distance accuracy
In either case, the input feature is reprojected to a local coordinate system centered on its bounding box. Though all the output features will be centered on a common origin (with the exception of features located very near the poles) and appear stacked on top of each other, each one retains the specifics of its reprojection (and so original position), and can be safely reprojected back into a projected or geographic coordinate system.
Note that Z values are not considered, so areas or distances are best preserved for geometry at an ellipsoid height of 0 meters.
Rasters
Additional parameters are available for raster features, specifying how the reprojected cells are to be interpolated.
This transformer is not affected by raster band and palette selection.
In this example, we have a set of neighborhood polygons. Note that the coordinate system is known, UTM83-10, and the extents are provided in meters.
We want to reproject them to geographic coordinates, latitude and longitude, WGS84.
The features are routed into a Reprojector.
In the parameters dialog, we leave Source Coordinate System as its default, Read from feature. The Destination Coordinate System is set to LL84.
The output features have been reprojected.
- This transformer does not alter z values. For handling elevation or vertical coordinate systems, consider using a CsmapReprojector.
 - For finer control, including Geographic Transformation selections, consider using a CsmapReprojector or EsriReprojector.
 - Some geographic areas have their own reprojection libraries and transformers. See Working with Coordinate System Transformers below.
 - This transformer operates on features with geometry. To reproject coordinates stored as attributes, see the AttributeReprojector or CsmapAttributeReprojector.
Coordinate System Support
        Looks up coordinate system names and definitions between FME’s internal format and common third-party and open source representations, storing the results as an attribute.  |
        Retrieves the name of the feature's assigned FME coordinate system into an attribute.  |
        Removes the coordinate system from features, without modifying geometry or coordinates.  |
        Assigns a specified coordinate system to features, without modifying geometry or coordinates.  |
        Assigns a specified local coordinate system to features, without modifying geometry or coordinates.  |
        Library  |
        Reprojects x and y coordinates stored as attributes from one coordinate system to another.  |
        FME (default) or Esri  |
        Reprojects one or more features to a local coordinate system centered on the bounding box containing all features.  |
        Converts a given angle from one coordinate system to another.  |
        Converts a given length from one coordinate system to another.  |
        Reprojects feature x and y coordinates from one coordinate system to another.  |
        Library (External Links)  |
        Reprojects x, y, and optionally z coordinates stored as attributes from one coordinate system to another using the CS-MAP library.  |
        Reprojects feature x, y, and optionally z coordinates from one coordinate system to another using the CS-Map library.  |
        Reprojects feature coordinates from one coordinate system to another using the Esri reprojection library.  |
        Great Britain Northern Ireland Republic of Ireland  |
        Reprojects feature coordinates from one coordinate system to another using the Grid InQuestII engine from Ordnance Survey, for use in Great Britain, Ireland, and Northern Ireland.  |
        Sweden  |
        Reprojects coordinates stored as attributes from one coordinate system to another using the Gtrans reprojection engine from the National Land Survey of Sweden (Lantmäteriet).  |
        Sweden  |
        Reprojects feature coordinates from one coordinate system to another using the Gtrans reprojection engine from the National Land Survey of Sweden (Lantmäteriet).  |
        Reprojects coordinates stored as attributes from one coordinate system to another using the PROJ library.  |
        Reprojects feature coordinates from one coordinate system to another using the PROJ library.  |
        Switzerland  |
        Reprojects feature coordinates from one coordinate system to another in Switzerland, using the Reframe library from the Federal Office of Topography (swisstopo).  |
Features reprojected as specified in parameters.
        Source Coordinate System  |
        Specify the coordinate system of the incoming features. The default is <Read from feature>, which reads the features’ existing coordinate system(s). Coordinate systems may also be explicitly selected from the FME Coordinate System Gallery, or provided by name via an attribute value or user parameter. If <Read from feature> is used and an input feature has no coordinate system assigned, the Destination Coordinate System is assigned to it and no reprojection is performed.  |
        Destination Coordinate System  |
        Specify the coordinate system to be reprojected to. Coordinate systems may be selected from the FME Coordinate System Gallery, or provided by name via an attribute value or user parameter.  |
        Interpolation Type  |
        Select a method for interpolating reprojected cell values:
        Cell Size  |
        Select a method for resizing cells:
        Tolerance (cells)  |
        Sets the tolerance, in cells, for approximating reprojected cell locations. Using the default value of 0.0, every cell will be reprojected. If a value greater than 0.0 is specified, some cell locations will be approximated. The difference between an approximated cell location and the true cell location should be at most the tolerance value. For example, if a value of 0.5 is specified, each approximated cell location should be maximum one-half of a pixel away from its true location. Increasing the Tolerance value may improve performance.  |
        Special Characters  |
Dialog Options - Tables
 Cut, copy, and paste may be used within a transformer, or between transformers.  |
        Generally resets the table to its initial state, and may provide additional options to remove invalid entries. Behavior varies between transformers.  |
                                                             Processing Behavior  |
                                                             Feature Holding  |
                                                             No  |
Search for all results about the Reprojector on the FME Community.
