PathBuilder
                                            Connects sequential line and/or arc features to create path geometry, preserving input segments.
Combining geometry when input features are arcs
Combining geometry while preserving the input segments
The PathBuilder receives features with line or arc geometry and connects them in the order received.
Gaps between input features are connected as follows:
Line to line or arc: the first line is extended to to start point of the next feature.
Arc to line: the line is extended from its start point to the end point of the arc.
Arc to arc: a two-point line connects the end of the first arc to the start of the second arc.
Z coordinates are supported. Features with matching x and y coordinates but differing z values at their connection points are handled according to the Connect Z Mode parameter.
Attributes may be collected as List attributes.
Note that path geometry is not supported in all output formats. See also: Line , Arc, and Path geometry.
In this example, a transit line is represented by a number of line segments, each approximately 1,000 meters in length, with varying numbers of coordinates per segment.
We want to combine these into a single geometry but keep the segment information intact.
The features are routed into a PathBuilder.
In the parameters dialog, the default settings are kept.
One feature is output with Path geometry. Note that the original segments are intact within the path and could be recreated using a PathSplitter.
If the features are processed using a LineBuilder, the segments are merged into a single line containing all coordinates of the input features. The input segmentation is lost.
- The Sorter may be useful for ordering features before using the PathBuilder.
 - It is possible to create self-intersecting paths with this transformer, which will not be rejected.
As the PathBuilder fills in gaps between features, it can produce unexpected results if the input features are not sorted correctly. To combine adjoining lines (without creating new geometry to connect gaps), use a LineCombiner (and ArcStroker, if arcs are present).
The PathSplitter will undo PathBuilder output.
Creating and Modifying Linear Features
These transformers work with lines in a variety of ways.
        Function  |
        Transformer Description  |
        Simple creation of lines from lines and/or points.  |
        Connects sequential point and/or line features to create line or area geometry.  |
        Combining adjoining lines into longer lines or complex paths, with more advanced geometry handling options than the LineBuilder.  |
        Connects line features that meet at common start or end points to create longer lines or paths.  |
        Combining arcs and lines into longer paths.  |
        Connects sequential line and/or arc features to create path geometry, preserving input segments.  |
        Turning linear features into areas.  |
        Turns input linear features into areas by adding their start point as the end point.  |
        Making linear features longer by a specific amount and at an appropriate angle.  |
        Creates two-point extensions to linear features that extend the feature by a user-specified length.  |
        Chopping features into smaller features.  |
        Breaks input features into points, lines, or areas. Chopped features contain the same set of vertices as input features.  |
        Breaking a path into its component segments (lines and arcs).  |
        Decomposes a path feature into its component segments.  |
        Shortening linear features by cutting off the ends.  |
        Shortens the geometry of a line feature from the ends by snipping specified distances, indices, or measure values. It operates on features with simple line geometry and polygons without holes.  |
        Intersecting lines and areas.  |
        Performs a line-on-area overlay, either splitting lines where they intersect area boundaries or subdividing areas where split by lines. Attributes may be shared between related lines and areas (spatial join).  |
        Intersecting lines and lines.  |
        Performs a line-on-line overlay in which all input lines are intersected against each other and resultant line features are created and output. Intersection points are turned into point features that can contain the merged list of attributes of the original intersected lines.  |
        Finding where points lay on lines.  |
        Performs a point-on-line overlay. Each input line is split at its closest place to any point within the specified point tolerance, and attributes may be shared between related points and lines (spatial join).  |
This transformer accepts features with line, arc, or path geometry. Where paths are input, they remain intact and other geometry is prepended or appended according to order of input.
Input segments combined into path features are output here.
Features with geometry other than valid line, arc, or path geometry are output via this port.
        Group By  |
        The default behavior is to use the entire set of input features as the group. This option allows you to select attributes that define which groups to form – each set of features that have the same value for all of these attributes will be processed as an independent group. The feature being created is output whenever a Group By value changes. When this happens, the feature with the differing attribute is not added to the current output feature; instead, it begins the next feature to be output.  |
        Complete Groups  |
 There are two typical reasons for using When Group Changes (Advanced) . The first is incoming data that is intended to be processed in groups (and is already so ordered). In this case, the structure dictates Group By usage - not performance considerations. The second possible reason is potential performance gains. Performance gains are most likely when the data is already sorted (or read using a SQL ORDER BY statement) since less work is required of FME. If the data needs ordering, it can be sorted in the workspace (though the added processing overhead may negate any gains). Sorting becomes more difficult according to the number of data streams. Multiple streams of data could be almost impossible to sort into the correct order, since all features matching a Group By value need to arrive before any features (of any feature type or dataset) belonging to the next group. In this case, using Group By with When All Features Received may be the equivalent and simpler approach. Note  Multiple feature types and features from multiple datasets will not generally naturally occur in the correct order.
        As with many scenarios, testing different approaches in your workspace with your data is the only definitive way to identify performance gains.  |
        Connect Z Mode  |
        Where connection points have matching x and y coordinates but differing z values, select a method for handling z. When viewed in 2D (ignoring Z), a path (which may define the border of a polygon) may appear to be closed as shown in the left figure below. This same path, when viewed in 3D, may appear to be open as shown in the right figure below.
        Aggregate Handling  |
        Select how aggregate geometries are to be handled:
        Generate List  |
        When enabled:
        Special Characters  |
Dialog Options - Tables
 Cut, copy, and paste may be used within a transformer, or between transformers.  |
        Generally resets the table to its initial state, and may provide additional options to remove invalid entries. Behavior varies between transformers.  |
                                                             Processing Behavior  |
                                                             Feature Holding  |
                                                             Yes  |
Search for all results about the PathBuilder on the FME Community.
