PathSplitter
                                            Decomposes a path feature into its component segments.
Each output feature will contain a copy of the source feature's attributes. Non-path input features will be output untouched.
        Segment Number  |
        If specified, each output feature is given an attribute containing the part's segment index within the original path feature.  |
        Segment List  |
        The optional List Attribute is used to associate attributes with each segment of the path. If the feature has a list of attributes that are in parallel to the members of the aggregate, these can be decomposed onto the output features by specifying this parameter.  |
        Special Characters  |
Dialog Options - Tables
 Cut, copy, and paste may be used within a transformer, or between transformers.  |
        Generally resets the table to its initial state, and may provide additional options to remove invalid entries. Behavior varies between transformers.  |
Search for all results about the PathSplitter on the FME Community.
