BoundsExtractor
                                            Extracts a feature’s minimum and maximum coordinate values into attributes.
Determining a feature’s extents as attribute values instead of geometry.
The BoundsExtractor receives features with any type of geometry and individually extracts their minimum and maximum x, y, and z coordinate values, storing them as attributes.
Where coordinate values do not exist (such as z values on 2D geometry or non-spatial features) a value of zero (0) is assigned.
To exclude an attribute, leave the parameter blank and it will not be added to the output features.
Feature geometry is unchanged.
In this example, we have a set of transit line features and wish to extract their bounds as attribute values.
Note that the features have Min and Max Extents values as geometry, but not attributes.
The features are routed into a BoundsExtractor.
In the parameters dialog, we keep the default attribute names provided.
The output features have new attributes containing the minimum and maximum coordinate values. Note that the features are 2D, and so the z values are zero (0).
Point cloud extents need to be recalculated after some operations. Consider using the PointCloudPropertyExtractor and its Calculate and Update Extents parameter instead.
To extract minimum and maximum values on attributes, use the StatisticsCalculator.
Creating Boxes and Rectangles
Creating rectangular geometry is a common task. These transformers do so in a variety of ways.
        Transformer  |
        Function  |
        Creates one or more new features with box geometry of a specific size and position (when Geometry Object is Box).  |
        Replaces an existing feature’s geometry with a box of a specific size and position.  |
        Creates one rectangle that encompasses all features received.  |
        Individually replaces the geometry of each feature with a rectangle that covers its extents.  |
        Individually replaces the geometry of each raster feature with a rectangle that covers its extents (with various Extents Type options).  |
        Extracts the coordinate values that describe an individual feature’s bounding box (or cube) and stores them as attributes.  |
        Creates a series of regularly-spaced rectangles that span the extent of all features received (when Type of Grid to Create is Polygons).  |
        Creates a series of regularly-spaced rectangles of a specific size and position (when Type of Grid to Create is Polygons).  |
        Tiler and RasterTiler  |
        Do not create actual rectangles, but chop features into a series of rectangular tiles, specified in a similar fashion to the 2DGridAccumulator.  |
Features with attributes containing minimum and maximum coordinate values.
        Minimum X  |
        Name the attribute to contain the minimum x value.  |
        Maximum X  |
        Name the attribute to contain the maximum x value.  |
        Minimum Y  |
        Name the attribute to contain the minimum y value.  |
        Maximum Y  |
        Name the attribute to contain the maximum y value.  |
        Minimum Z  |
        Name the attribute to contain the minimum z value.  |
        Maximum Z  |
        Name the attribute to contain the maximum z value.  |
        Special Characters  |
Dialog Options - Tables
 Cut, copy, and paste may be used within a transformer, or between transformers.  |
        Generally resets the table to its initial state, and may provide additional options to remove invalid entries. Behavior varies between transformers.  |
                                                             Processing Behavior  |
                                                             Feature Holding  |
                                                             No  |
Search for all results about the BoundsExtractor on the FME Community.
