2DBoxReplacer
                                            Replaces feature geometry with a 2D box defined by specified minimum and maximum x and y values.
Creating search envelopes
Creating clip boundaries
The 2DBoxReplacer receives features of any kind and replaces their geometry with 2D boxes as specified in parameters.
The parameters describe rectangular geometry with minimum and maximum x and y values, representing the box's lower left and upper right corners, in the ground units of the feature’s coordinate system.
Values may be entered directly or provided via attributes, parameters, or expressions.
In this example, we have a point dataset of food cart vendors. We want to replace the points with boxes centered on the point locations.
Note that the features have a UTM coordinate system, with ground units in meters.
The features are routed into a 2DBoxReplacer.
In the parameters dialog, expressions are created to offset the corners by 50 meters from the point location.
The points have been replaced with boxes.
Creating Boxes and Rectangles
Creating rectangular geometry is a common task. These transformers do so in a variety of ways.
        Transformer  |
        Function  |
        Creates one or more new features with box geometry of a specific size and position (when Geometry Object is Box).  |
        Replaces an existing feature’s geometry with a box of a specific size and position.  |
        Creates one rectangle that encompasses all features received.  |
        Individually replaces the geometry of each feature with a rectangle that covers its extents.  |
        Individually replaces the geometry of each raster feature with a rectangle that covers its extents (with various Extents Type options).  |
        Extracts the coordinate values that describe an individual feature’s bounding box (or cube) and stores them as attributes.  |
        Creates a series of regularly-spaced rectangles that span the extent of all features received (when Type of Grid to Create is Polygons).  |
        Creates a series of regularly-spaced rectangles of a specific size and position (when Type of Grid to Create is Polygons).  |
        Tiler and RasterTiler  |
        Do not create actual rectangles, but chop features into a series of rectangular tiles, specified in a similar fashion to the 2DGridAccumulator.  |
The dynamic <Rejected> port appears when a parameter is set to a non-literal value that might make processing impossible.
For example, if a numeric parameter such as Line Width, Count Start, or Decimal Places is set to an expression, attribute value, or user parameter, it is possible to pass in a non-numeric value that cannot be used. Decimal Places = Cat cannot be processed, so the feature will be output via this port.
Rejected features will have an fme_rejection_code attribute explaining the reason for rejection.
        Min X Value  |
        Specify the minimum x value (lower left) of the box.  |
        Min Y Value  |
        Specify the minimum y value (lower left) of the box.  |
        Max X Value  |
        Specify the maximum x value (upper right) of the box.  |
        Max Y Value  |
        Specify the maximum y value (upper right) of the box.  |
        Special Characters  |
Dialog Options - Tables
 Cut, copy, and paste may be used within a transformer, or between transformers.  |
        Generally resets the table to its initial state, and may provide additional options to remove invalid entries. Behavior varies between transformers.  |
                                                             Processing Behavior  |
                                                             Feature Holding  |
                                                             No  |
Search for all results about the 2DBoxReplacer on the FME Community.
