ArcGISOnlineConnector
                                            Accesses Esri ArcGIS Online or Portal for ArcGIS to upload, manage, update, download, delete, publish, share, or list information about items from an Esri ArcGIS account.
- Manage datasets and supplementary files on ArcGIS Online or Portal for ArcGIS by uploading, downloading, publishing, sharing, and deleting files and folders
 - Transfer a file's contents into or out of an attribute in FME
 - Read downloaded ArcGIS data using the FeatureReader, or upload data written by the FeatureWriter to ArcGIS Online or Portal for ArcGIS
 - Retrieve file and folder names, paths, links and other information from ArcGIS Online or Portal for ArcGIS for use elsewhere in a workspace
The ArcGISOnlineConnector uses either your ArcGIS Online or Portal for ArcGIS account credentials (either via a previously defined FME web connection, or by setting up a new FME web connection right from the transformer) to access the file storage service.
Depending on your choice of actions, it will upload or download files, folders, and attributes; list information from the service; share items which already exist in the user’s online content; publish items as feature layers; or delete items from the service. On Uploads, link attributes are added to the output features. On List actions, links and file/folder information are added as attributes.
- This transformer cannot be used to directly move or copy files between different ArcGIS user content folders or locations. However, multiple ArcGISOnlineConnectors can be used to accomplish these tasks.
 - Uploading data to ArcGIS is performed via synchronous multipart upload. Each file chunk is 20MB. The connector will upload these chunks consecutively and if a chunk upload fails, the connector will retry each upload up to five times.
 - Early termination of translations when performing publish/update/upload actions may result in malformed ArcGIS item entries. (When publishing, a feature service may be created but any title/tags specified for it may not be honored). (When updating/uploading, it is possible for the metadata to be uploaded before the file content has been uploaded).
 - The FeatureReader can access online ArcGIS content directly (without using the ArcGISOnlineConnector), however, a local copy of the dataset will not be created.
The output of this transformer will vary depending on the Action performed.
- A Delete action outputs no additional attributes.
 - A Download action can save to a file, a folder, or an attribute. If it saves to a file or folder, it will output the path it saved to an attribute.
 - A List action will output a new feature for each file/folder found in the path specified. Each of these new features will have attributes listing various pieces of information about the object.
 - A Publish action will output information about the feature service it created, including its id, feature service type and URLs to the feature service itself as well as its ArcGIS content page.
 - A Share action outputs no additional attributes.
 - An Upload action will output the id of the uploaded item and a link to its ArcGIS content page.
 - An Update action will output the id of the updated item and a link to its ArcGIS content page.
The incoming feature is output through this port.
Features that cause the operation to fail are output through this port. An fme_rejection_code attribute describing the category of the error will be added, along with a more descriptive fme_rejection_message attribute which contains more specific details as to the reason for the failure.
        ArcGIS Connection  |
        Performing operations against an ArcGIS Online or Portal for ArcGIS account requires the use of OAuth2 authentication using a Web Connection. To create an ArcGIS connection, click the 'ArcGIS Connection' drop-down box and select 'Add Web Connection...'. The connection can then be managed via Tools -> FME Options... -> Web Connections. To create an ArcGIS Portal Connection, users must create their own web connection based on the Esri ArcGIS Portal Web Service template provided with FME. From FME Workbench, open FME Options > Web Connections and click the Manage Services button. Navigate to the Esri ArcGIS Portal template. The resulting web connection can be used with the transformer.  |
        Action  |
        The type of operation to perform. Choices include:
The remaining parameters available depend on the value of the Request > Action parameter. Parameters for each Action are detailed below.
Delete an existing item/folder from a user’s own ArcGIS Online content.
Content Source
        Path  |
        The Item ID of a file or folder on ArcGIS Online or Portal for ArcGIS to delete. If valid credentials have been provided as a web connection, you may browse to a location in the user’s content. The user must be the owner of this item. Notes:
Download a file/folder to an attribute/file/folder from a user’s ArcGIS content or a group they have access to.
Content Source
        Content Source  |
        Select the source type of the content to be downloaded
        Group ID  |
        The ArcGIS group which the content is linked to. Note:
        Path  |
        The ArcGIS Item ID of a file or folder to download. If valid credentials have been provided as a web connection, you may browse to a location. Depending on the value of the Content Source parameter, this will list either the contents of the specified group or the user’s own ArcGIS content. Only items which can be downloaded will be displayed. If the user has permission to access items stored in other locations, the id of those items can be manually entered in this field.  |
Destination
        Download as  |
        Select whether to store the downloaded data in a File, Folder or Attribute.
        Download to Attribute  |
        Specify the attribute that will store the contents of the downloaded file. Valid for Download as Attribute only. Note  FME will attempt to convert the attribute's contents to a UTF-8 string. If this fails, the attribute's contents will be created as raw binary. To ensure that the original bytes are always preserved and never converted to UTF-8, use Download as File instead.
        Download to Folder  |
        Specify the path to the folder that will store the downloaded file. Valid for Download as File or Folder.  |
        If File Exists  |
        Whether to overwrite existing files in the target destination. Valid for Download as File or Folder.  |
        Include Subfolders  |
        Whether to include subfolders when downloading a folder. Due to the way that ArcGIS content is structured, only the root folder contains subfolders. Valid for Download as Folder .  |
Output Attributes
        _download_path  |
        Return the path the file/folder was downloaded to. If a folder was downloaded, the path will have a trailing slash.  |
List the item details for the contents of a group, a user’s folder, a user’s root folder, or all of a user’s content.
Content Source
        Content Source  |
        Select the source type of the content to be listed
        Group ID  |
        The ArcGIS group which the content is linked to.  |
        User Content Folder  |
        The ArcGIS folder ID to list the contents of, or ‘/’ for root. If valid credentials have been provided as a web connection, you may browse to a location in the user’s content. Only folders may be selected. Valid when Content Source is set to User.  |
        Whether to include subfolder content when listing. Due to the way that ArcGIS content is structured, only the root folder contains subfolders. Valid when Content Source is set to User.  |
Output Attributes
        _id  |
        Return the ID of a stored ArcGIS object.  |
        _name  |
        Return the title of a stored ArcGIS object.  |
        _file_or_folder  |
        Return the type (file or folder) of a stored ArcGIS object.  |
        _private_url  |
        Return the link to an object on ArcGIS. If the object is an item, this will direct the user to the ArcGIS web content page for their item. If the object is a folder, this will direct the user to the ArcGIS web content listing of items for their folder.  |
        _created  |
        Return the creation time (UNIX timestamp) of a stored ArcGIS object.  |
        _file_size  |
        Return the size of a stored ArcGIS object (in bytes). File only.  |
        _file_type  |
        Return the file extension of a stored ArcGIS object. (for example, ‘zip’ or ‘csv’) File only, and only if the file is downloadable.  |
        _is_downloadable  |
        Returns a flag (Yes/No) depending on whether or not the ArcGISOnlineConnector can be used to download this object. File only.  |
        _item_type  |
        Return the ArcGIS type of a stored ArcGIS object. File only.  |
        _json_response  |
        Return the JSON response provided directly from the API for this item.  |
        _last_modified  |
        Return the last modified time (UNIX timestamp) of a stored ArcGIS object. File only.  |
        _sharing_permissions  |
        Return the level of access to the item (private, shared, org, public). A ‘shared’ item is an item that has its sharing level set to private but has been shared to groups. File only.  |
        _webservice_url  |
        Return the URL which hosted feature services can be accessed at. Only valid for feature-service like ArcGIS items.  |
        _tags{}  |
        A list attribute which returns the tags associated with an item. File only.  |
Publish an existing ArcGIS item as a feature service. ArcGIS item types which the connector supports for publish:
- Shapefile
 - CSV
 - Microsoft Excel
 - Feature Collection
 - GeoJson
 - File Geodatabase
 - Scene Package
 - SQLite Geodatabase
 - Image Collection
 - Service Definition
 - Tile Package
 - Compact Tile Package
 - Vector Tile Package
Extra Usage Notes for Publish:
- csv/excel files will be analyzed and have some publishing parameters autogenerated for them. The generated publishing parameters will be logged at the info level.
 - For CSV files, ArcGIS will attempt to classify the file as containing either coordinate data, address data, lookup data, or no location data. If the CSV file is classified as having location data but ArcGIS cannot determine the relevant fields containing this data, the ArcGISOnlineConnector will log a warning and publish the CSV file as though it does not contain any location data. The resulting feature service will be a table.
Publishing Options
        Content Source  |
        The Item ID of a stored ArcGIS file to publish. If valid credentials have been provided as a web connection, you may browse to a location in the user’s content. Only publishable items should be displayed in the browser. The user must be the owner of this item. Note:
        Feature Layer Title  |
        The name to set for the newly created feature layer in ArcGIS. If this is left blank, the published item will use the existing title of the source item. Note:
        Feature Layer Tags  |
        The tags that the published feature layer should have in ArcGIS. If this is left blank, it published item will have the existing tags of the source item.  |
        Coordinate System  |
        Specify the target spatial reference of the created feature service. If not specified, this will default to WKID 102100.  |
Wait Behavior
        Wait for Publish Processing  |
        Whether to wait for the feature service created to publish
        Processing Timeout (s)  |
        The amount of time (seconds) to wait for the feature layer to publish. If not specified, this will default to 180 seconds.  |
Output Attributes
        _id  |
        Returns the ID of the feature service which was just created.  |
        _private_url  |
        Returns the link to the ArcGIS Online web content page for the newly created feature service  |
        _service_type  |
        Returns the type of service created with the publish operation  |
        _webservice_url  |
        Returns the URL which the newly created feature service can be accessed at. Only valid for feature-service like ArcGIS Online items.  |
Change the sharing level of a user’s ArcGIS Online content item or share it to additional groups.
Content Source
        Path  |
        The Item ID of an ArcGIS file to share. If valid credentials have been provided as a web connection, you may browse to a location in the user’s content.  |
Sharing
        Share Level  |
        Specify the sharing level to set for the item.
        Share to Additional Groups  |
        Select additional groups to share the item to. If there is a valid web connection, a list of all the groups the user belongs to will be displayed. Groups are listed with space separated IDs. Notes:
Update the data stored for an existing ArcGIS item and optionally specify new title/tags for that item.
Content Source
        Path  |
        The Item ID of an ArcGIS file or folder to update. If valid credentials have been provided as a web connection, you may browse to a location in the user’s content. Only items which have data that can be updated by the connector will be displayed. If the user has permission to access items stored in other locations, the id of those items can be manually entered in this field.  |
Data Source
        Upload  |
        The type of data to update with.
 When working with large objects, File is a better choice than Attribute as the data will be streamed directly from disk and not require that the object be stored entirely in memory on a feature.  |
        File to Upload  |
        The file to be uploaded to ArcGIS. Valid if Uploading from File. The file type (file extension) must match that of the target update item, otherwise the feature will be rejected.  |
        Attribute to Upload as File  |
        The attribute to upload data from. Valid if Uploading from Attribute.  |
Metadata
        Title  |
        Specify a new title for the target item. If this is left blank, the title will not change.  |
        Tags  |
        Specify new tags for the target item. If this is left blank, the tags will not change. Tags should be provided as a comma separated list.  |
Output Attributes
        _id  |
        Returns the ID of the target item which was just created.  |
        _private_url  |
        Returns the link to the ArcGIS web content page for the updated item  |
Upload a file or attribute to a location in a user’s ArcGIS Content
Data Source
        Upload  |
        The type of data to be uploaded.
        File to Upload  |
        The file to be uploaded to an ArcGIS account. Valid if Uploading from File.  |
Metadata
        Title  |
        The name to set for the uploaded item.  |
        Item Type  |
        The ArcGIS item type that the uploaded file should have. Notes:
        Tags  |
        Specify tags for the created item. Tags should be provided as a comma separated list.  |
Content Destination
        The ArcGIS folder ID to upload to. The name of a user’s ArcGIS Folder can also be used, provided that it does not conflict with the ID of an existing folder. If no such folder exists, one with that name will be created. If valid credentials have been provided as a web connection, you may browse to a location in the user’s content. Only folders may be selected. Note:
        Upload with File Name  |
        The name of the file created from the data supplied in Attribute to Upload as File. The name must include a filename extension (for example, .csv, .jpg, .zip).  |
Output Attributes
        _id  |
        _private_url  |
        Returns the link to the ArcGIS web content page for the updated item.  |
        Special Characters  |
Dialog Options - Tables
 Cut, copy, and paste may be used within a transformer, or between transformers.  |
        Generally resets the table to its initial state, and may provide additional options to remove invalid entries. Behavior varies between transformers.  |
                                                             Processing Behavior  |
                                                             Feature Holding  |
                                                             No  |
| Dependencies | Esri Access |
| Aliases | AGOLConnector, ArcGISPortalConnector |
| History | Released FME 2020.1 |
Search for all results about the ArcGISOnlineConnector on the FME Community.
