3DArcReplacer
                                            Replaces the geometry of the feature with a three-dimensional arc whose shape is set by the parameters, which can be either constant floating point values or the values of existing attributes.
Creating and Modifying Arcs, Circles, and Ellipses
These transformers work with arcs in a variety of ways.
        Function  |
        Geometry Out  |
        Z Coordinates  |
        Creates one or more new features with arc geometry (when Geometry Object is an arc type).  |
        Arc by center point Arc by center point with ends Arc by 3 points Arc by bulge Ellipse (Arc by center point)  |
        Supported  |
        Replaces any existing feature’s geometry with a 2D arc.  |
        Arc by center point  |
        No  |
        Replaces any existing feature’s geometry with a 3D arc.  |
        Yes, at center point  |
        Replaces an existing feature’s geometry with a 2D ellipse or circle (closed arc).  |
        No  |
        Modifies an existing arc or converts a point to an arc.  |
        Arc by center point Arc by center point with ends Arc by 3 points  |
        Supported, at center and/or ends  |
        Modifies an existing ellipse (closed arc) or converts a point to an ellipse.  |
        Supported, at center point  |
        Extracts the property values that describe an arc’s geometry and stores them as attributes.  |
        Arc by center point Arc by center point with ends Arc by 3 points Arc by bulge  |
        Supported  |
        Extracts the property values that describe an ellipse’s geometry and stores them as attributes.  |
        Supported  |
        Converts arcs and ellipses to lines or polygons by interpolating points along the arc.  |
        Path Line Area  |
        Supported  |
        Replaces geometry with an arc described by the first, middle, and last vertices of the input feature.  |
        Arc by 3 points  |
        Supported  |
        Replaces lines or polygons with an optimal combination of line and arc segments, creating smooth curving lines.  |
        Path Area Arc by bulge Line  |
        Supported  |
        Reduces point density on lines or polygons, fitting arcs where possible (When using Algorithm > Douglas With Arc Fitting (Generalize) ).  |
        Path Area Arc by 3 points Line  |
        Supported  |
        Either replaces an existing feature’s geometry with circle that contains all of its vertices or extracts the circle property values into attributes.  |
        No  |
        Center X  |
        The center x, y, and z parameters set the origin of the arc.  |
        Center Y  |
        Center Z  |
        Primary Radius  |
        The primary and secondary radius set the radii of the arc. Note that the primary radius need not be larger than the secondary, however, the rotation angle is always measured from the x axis to the primary axis. To make a circular arc, set both the primary and secondary radius to the same value.  |
        Secondary Radius  |
        Start Angle  |
        The start angle controls where the arc begins, and is measured in degrees counterclockwise from horizontal.  |
        Sweep Angle  |
        The sweep angle controls the duration of the arc, and is measured in degrees. The arc will run from the start angle to the start angle plus the sweep angle.  |
        Rotation  |
        The rotation angle is measured in degrees counterclockwise from horizontal, and measures the rotation of the primary axis from horizontal.  |
        Special Characters  |
Dialog Options - Tables
 Cut, copy, and paste may be used within a transformer, or between transformers.  |
        Generally resets the table to its initial state, and may provide additional options to remove invalid entries. Behavior varies between transformers.  |
Search for all results about the 3DArcReplacer on the FME Community.
