StringSearcher
Performs a regular expression match on the specified expression.
If the expression matches the pattern, the feature is output via the Matched port, and the portion of the original search string that matched the regular expression is stored in the attribute specified in the Matched Result Attribute (and optionally matching pieces of the expression are stored in the attribute list specified in the All Matches List Name and Subexpression Matches List Name parameters, along with the starting indices of each piece). Otherwise, it is output via the NotMatched port.
- Output feature order may be controlled with the Advanced > Preserve Feature Order parameter.
- To replace substrings matching a regular expression in a string, use the StringReplacer transformer.
Test regular expressions with the Regular Expression Editor in the Contains Regular Expression field’s context menu.
For more information on regular expression syntax, see https://perldoc.perl.org/perlre#Regular-Expressions.
Search In |
The input text to be searched. |
Contains Regular Expression |
To use this transformer to parse out portions of a string, regular expressions are used. The portion of the input text that matched the regular expression is stored as an entry in the All Matches List Name list. The elements of this list can then be exposed to FME Workbench by right clicking on it and indicating the number of elements to expose for later use. See below for some examples. Advanced Regular Expressions (AREs) are supported. For a complete description of AREs, see Syntax of Perl-Compatible Regular Expressions at https://perldoc.perl.org/perlre#Regular-Expressions. In brief, an ARE is one or more branches, separated by |, matching anything that matches any of the branches. A brief summary of the special characters and their meanings is:
Examples:
The Contains Regular Expression field can also include any number of special characters. Characters can be expressed as regular characters but they can also include any number of control characters. Special character sequences are interpreted as shown below:
Defining Special CharactersYou can define special characters through the Text Editors. Click Open Text Editor from the parameter menu:
Text Editor Enter characters using the shortcuts from the table above. Note To see tab characters, click the Options menu on the bottom left and select Show Spaces/Tabs.
Case Sensitive |
Note that the matches can be either case-sensitive or case-insensitive, depending on how the transformer is configured. |
Preserve Feature Order |
All Matches List Name |
The optional name for the list attribute to store all matches. This parameter is left empty by default. For example, if All Matches List Name was somelist and the string "Oct 15 1915; Apr 7 1964; May 21 1937" was searched with the regular expression \d{4}, all 4 digit strings would be matched, and we would have the following result: somelist{1} = 1915 somelist{2} = 1964 somelist{3} = 1937 Note List attributes are not accessible from the output schema in FME Workbench unless they are first processed using a transformer that operates on them, such as ListExploder or ListConcatenator. Alternatively, AttributeExposer can be used.
Subexpression Matches List Name |
The optional name for the list attribute to store subexpression matches. The difference between this list and All Matches List Name is the matches listed here are from capture groups, which are regex subexpressions contained by brackets. This parameter is left empty by default. Note List attributes are not accessible from the output schema in FME Workbench unless they are first processed using a transformer that operates on them, such as ListExploder or ListConcatenator. Alternatively, AttributeExposer can be used.
Matched Result |
Name the attribute to contain the matching result. The default attribute name is _first_match. |
Dialog Options - Tables
Search for all results about the StringSearcher on the FME Community.
Keywords: Grepper
