AttributeExposer
- Exposing attributes that a workspace is not aware of, such as those created by a SchemaMapper
- Exposing normally unexposed fme_ and format-specific attributes for use in the workspace
- Exposing attributes in a dynamic translation where source attributes may vary
The AttributeExposer makes unexposed attributes visible in FME Workbench so they can be used elsewhere in the workspace. This transformer is useful if you know features have an attribute, but that attribute is not currently showing as available in your workspace. For example:
- FME Attributes (fme_) and more obscure format-specific attributes that are not automatically shown in FME Workbench.
- Transformers, such as the SchemaMapper, that dynamically add attributes onto features which FME Workbench is not aware of.
You may enter the attribute names manually, import attributes from any supported source dataset, or import from upstream feature caches. Known attributes (including fme_ and format-specific attributes that are not currently exposed) can be selected from the drop-down menu.
This transformer only exposes the attribute in FME Workbench - it does not ensure that valid attribute names are being exposed. The input features are not modified in any way.
Once the attributes are exposed, they can be accessed elsewhere in the workspace.
Data Type may be optionally set or changed.
Cached Values and Data-Aware Attribute Names
If Feature Caching is enabled, valid attribute names from upstream features are shown for attribute selection.
In this example, we have a Parks dataset, and want to change the attribute names to match a desired schema. We route the Parks features into a SchemaMapper, which uses an external CSV file (lookup table) to map the attribute names to new ones.
The attribute map created in the SchemaMapper will take care of creating new attributes with the existing values, but FME Workbench does not yet know that the new attribute names exist on these features, and so cannot expose them in the workspace.
In the AttributeExposer parameters dialog, we add the names of the attributes we want to expose for use elsewhere in the workspace. The names could be entered manually, selected from the drop-down if Feature Caching is turned on, or imported using the Import button and reading the names from the same CSV file used in the SchemaMapper.
Setting the data Type here is optional.
The features are then sent into an AttributeManager to remove the original, unwanted names, and reorder the attributes.
- Expose attributes fme_basename and fme_dataset in the reader feature type or the FeatureReader transformer. These attributes are not read unless they are exposed in this manner.
Features with attributes.
Features with exposed attributes.
Attributes
Enter attribute names or choose them from the drop-down list (which provides access to fme_ and format-specific attributes). The order in which they appear in the list is the order in which they will appear in the Output port of the transformer. Import: Use this to import attribute names from any supported source dataset or upstream feature cache. |
Type |
(Optional) Specify the attribute's data type. The ellipses button will open an Attribute Type Definition dialog, which can assist with setting Type, Width, and Precision (where necessary). Type will be populated if Import is used to read a dataset or upstream feature cache. The attribute is tagged with the specified Type information, but type limitations are not enforced on values at this point, and so mismatches between type and value are possible. Type may be enforced elsewhere in the workspace, such as in writers or by using an AttributeValidator or Tester to check values against type. Available data types include:
Dialog Options - Tables
Dependencies | None |
Aliases | |
History |
Search for all results about the AttributeExposer on the FME Community.
