RasterExpressionEvaluator
Evaluates expressions on each cell in a raster or pair of rasters, including algebraic operations and conditional statements.
- Performing calculations on rasters or pairs of rasters
- Manipulating images
- Combining rasters
- Classifying rasters
The RasterExpressionEvaluator receives raster features and evaluates defined expressions using the cell values, then outputs new raster features with the calculated values.
Input Mode - One or Two Rasters
The transformer has two modes - One Raster and Two Rasters.
One Raster mode provides a single input port -the A port. In this mode, expressions will be evaluated wholly within a single raster.
Two Rasters mode provides two input ports - A and B. In this mode, expressions can use cell values from two rasters of the same dimensions (same number of rows and columns). Position information for georeferenced rasters is not taken into consideration. The number of input raster features may be:
- If One Raster (A) - one or more A raster, no B rasters.
- If Two Rasters (A and B) - one A raster, one or more B rasters. The single A input will be paired with each B input.
All bands used in the same expression must have the same Nodata value, or have no Nodata value at all. No band may have a palette.
In Two Raster mode, if an expression references both the A and B input raster features, the output raster will have all the attributes from both feature A and B. If the same attribute exists on both input features, then the attribute value from feature B will be preferred.
When only a single input is being operated on (for example, in One Raster mode or if the expression only references input A), the feature attributes and raster properties will remain unchanged.
Expressions
Expressions are defined in the Band Expression(s) table. Each line in the table corresponds to one band in the output raster, in sequential order - that is, the first line produces Band 0, second line produces Band 1, and so forth. The Interpretation Type for each output band is also specified here.
Expressions may be as simple a constant value or simple arithmetic operation. The Arithmetic Editor - Raster Expression is available via the Expression ellipsis (...) button to assist in the construction of expressions.
Expressions are case-sensitive.
Note that when converting between different data types, a Bounded Cast is used. As a result, when a calculated value does not fit in the specified destination interpretation, the corresponding destination value will either be set to the minimum or maximum value possible in the destination data type. For example, a value of 300, if converted to an unsigned 8-bit integer band, would become 255 (the maximum available value for that interpretation type).
Nodata and Zero (0) Values: Expression evaluation often involves changing interpretation types of values, and can sometimes result in unpredictable behavior particularly in the case of zero (0). When defining your expression, best practice is to specify zero in decimal form as 0.0 to avoid it being misinterpreted as Nodata.
Expression Syntax
Means... |
Or |
And |
Equal |
Not equal |
Less than |
Greater than |
A[x] |
Band x of raster feature A |
B[x] |
Band x of raster feature B |
Bands start counting at zero (so a three-band raster is A[0], A[1], and A[2]).
A statement can be as simple as these:
255 |
Set the value of the current cell to be 255. |
A[0]+1 |
Set the value of the current cell to be Raster A, band zero, plus 1. |
"if" statements allow a value to be set depending on conditions, in the form if (conditions, pass value, fail value):
if (A[0] < 255, 200, 255) |
If Raster A, band zero is less than 255, then set the current cell to 200, else leave it as 255. |
if (A[0]<50 || A[1]<50 || A[2]<50, 0, 255) |
If Raster A, band zero is less than 50 OR band one is less than 50 OR band two is less than 50, then set the current cell to 0, else set it to 255. |
Bands in two raster features can be referenced in the statement:
if (A[0]!=B[0] && A[0]<255, 0, A[0]) |
If Raster A band zero is not equal to Raster B band zero, AND Raster A band zero is less than 255, then set the current cell to 0, else set it to the value of Raster A band zero. |
Standard maths operators are permitted:
if (A[0] - B[0] == 255, 0, A[0]/5) |
If Raster A band zero minus Raster B band zero equals 255, then set the current cell to 0, else set it to the value of Raster A band zero divided by five. |
Attributes can be referenced using @Value and either A: or B: to refer to the attribute name:
A[0]*@Value(A:myattr) |
Multiply Raster A band zero by the attribute myattr on raster A. |
Expression |
Result |
255-A[0] |
Inverts an 8-bit band. For a 24-bit RGB image, repeat for A[1] and A[2] to invert the full image. Repeat for A[3] too if it is a 32-bit RGBA image. |
if ((A[0]+A[1]+A[2])==0, 255, A[0]) |
Convert black values into white in an RGB image. Repeat for A[1] and A[2] to invert black/white for the full image. |
A[0]*1.5 |
Increases the brightness of the red band in an RGB image. Repeat for A[1] and A[2] to brighten the full image |
@sqrt((A[0]*A[0]) + (B[0]*B[0])) |
Combines two raster cells together. An alternative would be to average the values: (A[0]+B[0])/2) |
if(A[0]==0,0,A[0]/@Value(A:_height+1)) |
Classify raster DEM cells into groups where group size is defined by the _height attribute |
In this example, we will convert a color raster to grayscale. Note that the original raster has three bands - Red, Green and Blue. Values from all bands will be used to calculate a single output value.
The values for each band on each cell will be used for calculations.
The raster is routed into a RasterExpressionEvaluator.
In the parameters dialog, we define a single expression to be calculated and stored in one single Gray band. The Interpretation is set to Gray8, and the Expression references cell values from all three incoming bands. (This formula uses commonly recommended values for color to gray scale conversion.)
Band numbering starts at zero (0), and so A[0] refers to the first band (Red), A[1] refers to the second band (Green), and A[2] refers to the third band (Blue).
The output raster feature contains only one band, the Gray8 band specified in the parameters.
The results of the expression evaluation are output as cell values.
In this example, we will use a RasterExpressionEvaluator to isolate land of a specific zoning type that falls with 150 meters of major arteries.
We start with two numeric rasters. The first represents zoning, with integer values ranging from 1 to 10, where each value arbitrarily represents a zone type. This will be our A raster.
We are interested in zone type 3.
The second raster represents 150 meter buffers along arterial roads. Cells have a value of either 0 or 1, where 1 represents pixels inside the buffer zones, and 0 outside the buffer zones. This is our B raster.
The pair of rasters is routed into a RasterExpressionEvaluator - note that Mode: Two Rasters must be selected in the parameters dialog prior to connecting the second raster, to enable (and expose) the B input port.
In the parameters dialog, we create a single expression. This will result in a single-band numeric raster being output. An Interpretation type must be specified - Int32 (32-bit integer) is chosen, as an appropriate interpretation type for these values.
The expression references cells from both the A and B rasters, and is using this form:
If the cell value from raster A (zones) is equal to 3, AND the cell value from raster B (artery buffers) is equal to 1, then output the cell value 3. Otherwise, set the cell value to 0.
Note that zero is specified in decimal form as 0.0 (avoiding misinterpretation as Nodata).
Any cells that fall within both zone 3 and an artery buffer are output with a value of 3, and all others cells are 0.
- To perform basic calculations between two rasters (Cell 1 <operator> Cell 2), consider using the RasterCellValueCalculator.
- To perform basic calculations between one raster cell and a numeric value, consider using the RasterSingularCellValueCalculator.
- To combine rasters, blending the edges of partial overlaps, consider using the RasterMosaicker.
- Nodata values can be set with the RasterBandNodataSetter or removed with the RasterBandNodataRemover.
- Palettes may be resolved using the RasterPaletteResolver or removed using the RasterPaletteRemover.
Choosing a Raster Transformer
Working with Rasters
Enhances the features of a raster image. The RasterSharpener enhances the borders, lines, and curves while reducing noise in the flat areas of the raster image. |
Working with Bands
Working with Cells
Working with Palettes
Workflow Control
Vectors and Rasters
Raster features to evaluate expressions against. Palettes are not supported.
The B input port is only exposed when Mode: Two Rasters is currently selected.
Raster features where bands are defined and values calculated according to parameter selections. One raster is output for each input raster in One Raster mode, and for each A/B pair in Two Raster mode.
INVALID_A_RASTER_NO_BANDS
INVALID_B_RASTER_NO_BANDS
INVALID_A_RASTER_MISSING_BAND
INVALID_B_RASTER_MISSING_BAND
MISSING_A_RASTER_MISSING_ATTRIBUTES
MISSING_B_RASTER_MISSING_ATTRIBUTES
EXTRA_A_RASTER_HAS_PALETTE
EXTRA_B_RASTER_HAS_PALETTE
Mode |
This parameter specifies how many types of input features are allowed. One Raster: Only A input features are permitted. Two Rasters:A and B input features are permitted. |
Group By |
If any Group By attributes are given, then each group will be treated independently. This allows a single transformer to operate on multiple pairs of As and Bs. Note that this parameter is not applicable when the Mode is One Raster; in that case, each raster is considered individually and there are no groupings. |
Complete Groups |
This table is used to specify how to calculate and interpret one or more bands in the output raster.
Each row of the table represents a different band in the output raster, in sequential order.
Interpretation |
Defines the Interpretation Type of each output band. Preserve: If all input bands share the same interpretation, the output band will preserve that interpretation. If the input bands do not share the same interpretation, Preserve is the same as Auto. Auto: The output interpretation will be automatically determined based on the data types used to perform the calculations. Alternatively, the Interpretation may be specified as any of the following:
Expression |
Define an expression to be evaluated. The Arithmetic Editor - Raster Expression may be accessed via the ellipsis (...) button to assist in creating expressions. The result of this expression will be stored in the corresponding band on the output raster. |
Dialog Options - Tables
Yes |
Search for all results about the RasterExpressionEvaluator on the FME Community.
