RasterCellValueCalculator
Evaluates basic arithmetic , minimum, maximum or average operations on the cell values of a pair of rasters.
- Recalculating raster cell values by processing them individually against another raster
The RasterCellValueCalculator receives pairs of raster features, and evaluates a defined arithmetic expression on the band values of each pair of corresponding cells.
Each pair of rasters must have:
- the same number of rows and columns
- the same number of bands (or selected bands)
- the same Nodata value, or have no Nodata value
The rasters are routed into A and B input ports, and an Operation is selected to perform, constructing a basic expression in the form A <operation> B. Operations available include addition, subtraction, multiplication, division, and three basic statistics - minimum, maximum, and average. The order of A and B is fixed, and matters for certain operations including division and subtraction.
The new values are output on the same band from which they were calculated. Preserve Interpretation determines whether or not the band is converted to a different type on output - for example, the division of two integers may produce a floating-point decimal result, converting the output band to interpretation type real64.
If the rasters are mismatched either in dimension (number of rows and columns) or number of bands (or selected bands), an error will occur.
Position information for georeferenced rasters is not taken into consideration.
For multi-band rasters, the first selected band of raster A is combined with the first selected band of raster B, the second selected band of raster A is combined with the second selected band of raster B, and so on. To restrict operation to specific band(s), use a RasterSelector prior to the RasterCellValueReplacer.
This transformer supports raster band selection. The RasterSelector can be used to modify the selection. Palettes are not supported.
In this example, we will use a RasterCellValueCalculator to isolate land zoning that falls with 150 meters of major arteries.
We start with two numeric rasters. The first represents zoning, with integer values ranging from 1 to 10, where each value arbitrarily represents a zone type. The selected pixel here, with a value of 10, is zoned Industrial This will be our “A” raster.
The second raster represents 150 meter buffers along arterial roads. Pixels will have a value of either 0 or 1, where 1 represents pixels inside the buffer zones, and 0 outside the buffer zones. This is our “B” raster.
The pair of rasters is routed into a RasterCellValueCalculator.
In the parameters dialog, the Operation is set to “/” - division. This will perform A / B, and so the zone values (from 1 to 10) will be divided by either 0 or 1.
Cells that fall within a buffer retain their original value (being divided by 1). Cells that fall outside the buffer fail to be divided by 0 - and so become “Nodata” values. The output raster feature is shown here over a blue background to show the Nodata areas clearly.
- To perform basic calculations between one raster cell and a numeric value, consider using the RasterSingularCellValueCalculator
- For more complex calculations, including multiple operators, consider using the RasterExpressionEvaluator.
- Nodata values can be set with the RasterBandNodataSetter or removed with the RasterBandNodataRemover.
- Palettes may be resolved using the RasterPaletteResolver or removed using the RasterPaletteRemover.
Choosing a Raster Transformer
Working with Rasters
Enhances the features of a raster image. The RasterSharpener enhances the borders, lines, and curves while reducing noise in the flat areas of the raster image. |
Working with Bands
Working with Cells
Working with Palettes
Workflow Control
Vectors and Rasters
Pairs of raster features to perform calculations on. Palettes are not supported.
Raster features with calculated values according to parameter selections, stored in the same band they were provided in.
Unselected bands are appended to the output raster, unchanged. The unselected bands of raster A are appended first, followed by the unselected bands of raster B.
INVALID_RASTER_NO_BANDS
EXTRA_RASTER_HAS_PALETTE
Group By |
To perform a calculation on more than one pair of rasters, a set of Group By attributes must be specified. Each group must contain one A raster and one B raster. Group By attributes are always added to the output feature. |
Complete Groups |
Operation |
The operation to perform. Choices include: + Add - Subtract * Multiply / Divide Minimum Maximum Average |
Preserve Interpretation |
Yes: Each output band will have the same interpretation as its input bands, as long as the input bands share the same interpretation. No: The interpretation of each output band will be automatically determined. If the input bands have different interpretations, the interpretation of each output band will be automatically determined. Note that when converting between different data types, a Bounded Cast is used. As a result, when a calculated value does not fit in the destination interpretation, the corresponding destination value will either be set to the minimum or maximum value possible in the destination data type. |
Accumulate Attributes |
If Yes, attributes from the original features will be merged onto the output feature. Group By attributes are always added to the output feature. If attributes on the A and B features share the same name, values from the B feature attributes take precedence. |
Dialog Options - Tables
Yes |
Search for all results about the RasterCellValueCalculator on the FME Community.
