PointCloudFilter
- Separating a point cloud into parts based on expressions using component values
- Isolating points in a point cloud based on expressions using component values
The PointCloudFilter receives point cloud features and divides them into individual point clouds, based on the evaluation of defined expressions, including component values. Each Expression has a corresponding Output Port.
One or more expressions may be defined. Each output point cloud will contain the points that matched that expression. Points that match more than one expression will be allocated to the first expression they match, in table order.
Points that do not match any expressions may be optionally output as <Unfiltered>. Empty point clouds will not be output.
Expression Syntax
An expression consists of a combination of operands, operators, and parentheses.
White space may be used between the operands, operators, and parentheses as it is ignored by the expression processor.
Operators
See Math Operators for a complete list and documentation.
Means... |
|| | Or |
&& | And |
== | Equal |
!= | Not equal |
< | Less than |
> | Greater than |
Operands
Operands may be any of the following:
Example(s) |
Description |
Component |
@Component(z) @Component(color_red) @Component(return) @Component(<user_component>) |
A component from an input point cloud. Note that if a component has a scale/offset, the "applied" value of the component will be used in the expression. |
Constant |
42 0 13.5 3. 6e4 7.91e+16 |
A numeric constant, either integer or floating-point. Where possible, numeric constants are interpreted as integer values; otherwise, operands will be treated as floating-point numbers. |
Attribute Value |
@Value(point_cloud_id) | The value of an attribute, using @Value() notation. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Function |
@sqrt(@Component(z)) @if(@Component(z) < 0,0,@Component(z)) |
A function whose arguments have any of the above forms for operands. Available functions include:
Note See Math Functions for a complete list of FME math functions and documentation. Not all functions are available in all contexts.
Private or Published Parameter |
$(User_Parameter)
Published and private parameters, including user parameters. See Creating and Modifying User Parameters. |
Types and Overflows
This transformer attempts to avoid overflows by changing data types through the course of evaluating an expression. For example, if two UInt8 values are added together, the internal computations will be performed with a UInt16 type; this ensures that no overflow will occur.
In general, performing an arithmetic operation on integer types will produce an integer type. The exception to this is division: it will always produce a floating-point result. Performing an arithmetic operation on floating-point types will always produce a floating-point type.
Note that when converting between different data types, a Bounded Cast is used. As a result, when a calculated value does not fit in the specified destination data type, the corresponding destination value will either be set to the minimum or maximum value possible in the destination data type. For example, a value of 300, if converted to an unsigned 8-bit integer component (UInt8), would become 255 (the maximum available value for that data type).
In this example, will filter a point cloud by using its classification values. Note that the source dataset is urban, with a mix of structures, roads, buildings, and vegetation.
The point cloud is routed into a PointCloudFilter.
In the parameters dialog, we create three expressions based on the classification component values.
Note that the Vegetation expression is more complex, looking for any one of three possible values (|| means “OR”).
Examining the output of the Buildings expression in the FME Data Inspector, we can see that this particular output feature contains only the points with a classification value of six, which are the buildings.
- The PointCloudSplitter provides similar functionality. It can split point clouds with simple range expressions, automatically detecting unique values for a component or first/last return. It does not provide multiple output ports.
For each expression entered in the Expression table, a corresponding Output Port is named and created.
If Output Unfiltered Points is Yes, points that do not match any of the specified expressions are output via the <Unfiltered> port.
INVALID_FEATURE_COMPONENTS
MISSING_FEATURE_ATTRIBUTES
MISSING_FEATURE_COMPONENTS
Expression |
Define an expression describing which points to include. The Arithmetic Editor may be accessed via the ellipsis (...) button to assist in creating expressions. |
Output Port |
Specify the name of an output port for the point cloud. |
Output Unfiltered Points |
Yes: Points that do not match any expression are output via the <Unfiltered> port. No: Points that do not match any expression will be discarded. No may improve performance. |
Dialog Options - Tables
Dependencies | None |
Aliases | |
History |
Search for all results about the PointCloudFilter on the FME Community.
Keywords: point "point cloud" cloud PointCloud LiDAR sonar
