PointCloudConsumer
- Performance testing or benchmarking point cloud processing.
- Debugging point cloud processing.
- Testing point cloud feature validity.
The PointCloudConsumer receives point cloud features and reads all of their data at their current state in the workspace. It does not perform any new operations on the point clouds.
FME handles point clouds in a “delayed evaluation” model. A point cloud reader reads essential information about a point cloud, but does not read the actual point contents until it is absolutely necessary. Transformer operations are accumulated until the results are needed, often being held until the features enter a writer. At that point, the required data is fully read and processed.
This is intended to optimize performance - for example, if a point cloud is both clipped and reprojected, FME will optimize processing by not reprojecting data that falls outside of the clip boundary and is ultimately discarded.
The PointCloudConsumer transformer forces this read to occur, and any accumulated operations are performed as the features are read. Nothing is done with the read features, and the transformer will not improve performance - it simply emulates the effect that reading the data would have, wherever it is placed.
It can be used to test workspace performance without configuring writers, and can also be useful for debugging point cloud processing workspaces with multiple accumulated operations. It may also be used for point cloud geometry validation, as it will reject any non-point cloud features.
In this example, we are building a point cloud processing workspace.
The source datasets are four LAS point clouds, totaling approximately 387 MB, which need to be reprojected, combined, have some component values calculated, and then be passed along for further processing.
As all of these operations will be accumulated until they are required (such as enter a writer), we cannot yet determine how long it might take to process this.
A run of the workspace as it stands is very fast, an indication that the point cloud operations have been held for later processing.
To get a more accurate idea of how long this will take, we add a PointCloudConsumer after the three point cloud processing transformers.
In the parameters dialog, we keep the default settings.
Running the workspace again, we can see that it will take more time to fully read and process the point clouds, with the accumulated operations applied.
- The Enable Feature Caching option in FME Workbench should be disabled to obtain more accurate processing benchmarks.
Point cloud features with no modifications made.
Block Size (Points) |
The point cloud will be consumed in blocks, reading this many points in each block. Adjusting this parameter is generally only useful for internal Safe testing. |
Dialog Options - Tables
Search for all results about the PointCloudConsumer on the FME Community.
Keywords: point "point cloud" cloud PointCloud LiDAR sonar
