DonutBuilder
Cuts holes in polygonal features by making polygons completely enclosed in other polygons into holes of the containing polygon.
The DonutBuilder assumes that the input area features are topologically clean. Further, it is assumed that any two input polygons within a group either have a strict containment relationship, or are not overlapping.
Aggregate features are decomposed recursively to their components and non-area features will be output via the <Rejected> port.
Example
The resulting donut and hole features will be output through this port.
Features with non-area or null geometry will be output through this port.
Rejected features will have an fme_rejection_code attribute with the value INVALID_GEOMETRY_TYPE.
Group By |
The default behavior is to use the entire set of input features as the group. This option allows you to select attributes that define which groups to form. Each set of features which have the same value for all of these attributes will be processed as an independent group. |
Complete Groups |
Connect Z Mode |
If applicable, select a method for handling z values. When viewed in 2D (ignoring Z), a path (which may define the border of a polygon) may appear to be closed as shown in the left figure below. This same path, when viewed in 3D, may appear to be open as shown in the right figure below.
Drop Holes |
The Drop Holes parameter indicates whether or not features used to cut holes in containing features should themselves be dropped or output. |
Merge Attributes
Accumulation Mode |
If Merge Hole is chosen, attributes from all features will be merged, and in case of conflicts, the value of the Conflict Resolution parameter will be used. If Prefix Hole is chosen, then all hole attributes will be presented with a prefix set in the Prefix parameter. If Replace with Single Hole is chosen, only attributes from hole features will be used. |
Conflict Resolution |
This parameter is enabled when Accumulation Mode is set to Merge Hole. Use Outer Shell and Use Hole will give priority to outer shells and holes respectively in case of attribute conflicts. |
Prefix |
The value is used as a prefix for hole attributes when Accumulation Mode is Prefix Hole. |
Generate List
When enabled, adds a list attribute to the output donut, retaining attribute values for each input feature that became a hole, in the order that the holes appear on the donut.
Hole List Name |
Enter a name for the list attribute. Note List attributes are not accessible from the output schema in FME Workbench unless they are first processed using a transformer that operates on them, such as ListExploder or ListConcatenator. Alternatively, AttributeExposer can be used.
Add To Hole List |
Selected Attributes |
Enabled when Add To Hole List is set to Selected Attributes. Specify the attributes you wish to be included. |
Hole Flag Attribute |
This parameter will be added to each output feature and will contain "yes" if that feature was used to cut a hole into some containing feature, and "no" if that feature was not used as a hole. Area features may be considered in groups based on the value of one or more attributes. Only features in the same group are then considered for hole nesting. |
Dialog Options - Tables
Search for all results about the DonutBuilder on the FME Community.
Keywords: island Donutizer
