Creating Workspaces from Templates
The Create Workspace dialog (File > New) contains a list of available templates, either stored locally or downloadable from FME Hub:
  1. This area lists template types and categories.
  2. This area displays the templates that are stored in the selected category on the left.
  3. The tabs contain information associated with the template.
  4. Filter templates by keyword.
Installed Templates
Some templates are included with each FME Form installation. These will be shown here, along with any templates that you download and install from FME Hub for use with both FME Form and FME Flow. Downloadable templates are updated frequently.
FME Hub
These templates are downloadable from FME Hub. FME Hub contains templates and custom transformers that are described as part of solutions in the FME Community, as well as workspace elements created by third parties.
Downloading a Template and Saving a Template as a Workspace
  1. To download a template, select it and click Choose, or double-click the template name.
  2. The FME Workbench log window shows the status of the download. The log window will look something like this:
Requesting catalog details for selected template...
Retrieved catalog details.
Connecting to FME Hub...
Successfully connected.
Downloading '<template_name>.fmwt.fmwt'...Successfully downloaded file.
Successfully downloaded '<template_name>.fmwt' from FME Server to '<default_location>\FME\FME Hub\Templates\LAS_PDF_3D.fmwt'.
Disconnecting...
Successfully disconnected.
Note  If you have an open workspace, you will be prompted to save and close the workspace.
  1. When the template opens in FME Workbench, it will already contain input data and transformers (if applicable), along with explanatory annotations.
  2. Click File > Save to save the template as a workspace on your computer. FME saves the template on your local drive. Additionally, FME creates a folder of the same name, in the same location, that contains any associated input data.
