GtransReprojector
Reprojects feature coordinates from one coordinate system to another using the Gtrans reprojection engine from the National Land Survey of Sweden (Lantmäteriet).
- Reprojecting features when explicitly using the Gtrans engine is desired
- Reprojecting features in select local coordinate systems not supported elsewhere
The GtransReprojector receives raster, vector, or point cloud features and reprojects their coordinates from one coordinate system to another, using the Gtrans engine and translation files.
Gtrans is widely used for coordinate transformation within Sweden as it is officially recommended, translates between numerous local coordinate systems, and supports rubbersheeting transformations.
The transformation is configured by selecting a Gtrans Translation File appropriate for the Source and Destination Coordinate System. For raster features, the Reverse Translation File must be identified as well.
Output features’ coordinate system will show as Unknown, as these features no longer have an FME coordinate system tag. If the output coordinate system is known to have an exact match in FME’s coordinate system library, it can be tagged manually with a CoordinateSystemSetter.
Translation Files
A selection of Gtrans Translation Files are provided with FME.
Only reprojections defined here or with a user-provided Gtrans Translation File (see below) may be performed with this transformer.
File Type |
Description |
Location |
*.tf, *.tfi |
Translation File - a text file containing parameters defining a reprojection from one coordinate system to another.
[FME Install Directory]\Reproject\Gtrans\Sys |
*.tr1, *.tr2 |
Triangulation File - a binary file used for the interpolation of residuals.
Each *.tf/*.tfi file corresponds to a line item in the Gtrans Translation Files library accessed in the parameters dialog.
Note that when using the Filter option, FME searches the file names of the *.tf/*.tfi files - not the Source and Destination Coordinate Systems.
Geoid Files
When reprojecting between geoids, this transformer needs additional resource files.
File |
Description |
Location |
geoid.def |
Geoid Definition File - a text file containing parameters describing geoids. A default version is provided with FME. User-provided geoids may also be used - see below. |
*.grd |
Binary Grid files for specific geoids. |
Gtrans User Data
Users may provide their own transformations and definitions by placing the appropriate files as directed:
File(s) |
Description |
Location |
*.tf, *.tfi |
The Translation File should reference the correct geoid.def and any required *.bin files. User-defined translations are placed in the same location as the provided Translation Files. |
[FME Install Directory]\Reproject\Gtrans\Arkiv |
geoid.def |
Geoid Definition File - a text file containing parameters describing geoids. A default version is provided with FME. The user version of this file is placed in a different location than the default geoid.def provided with FME. |
*.bin |
Rasters
Additional parameters are available for raster features, specifying how the reprojected cells are to be interpolated. Both the forward and Reverse Translation Files for the reprojection must be provided.
This transformer is not affected by raster band and palette selection.
In this example, we have a shapefile of waterways in Sweden, extracted from OpenStreetMap. We want to reproject the features to an appropriate national coordinate system using the Gtrans engine.
Note that the source data is tagged as lat/long geographic coordinates, WGS84.
The features are routed into a GtransReprojector.
In the parameters dialog, a Translation File is selected.
The Translation File was selected from the Gtrans Translation Files gallery, via the ellipsis button. Note that the chosen Source Coordinate System is SWEREF 99 lat long, an equivalent to LL-WGS84.
The output features have been reprojected. Note that FME no longer knows what the Coordinate System is - if the Destination Coordinate System has a known FME equivalent, it could be tagged using a CoordinateSystemSetter.
TFFIL Lantmäteriet 2006-08-24
Överräkning mellan SYSTEM:
SWEREF 99 13 30 Ellh-> SWEREF 99 lat long ellh
FSYSTEM SWEREF 99 13 30 Ellh/
HTYP ELLIPSOID METER/
TSYSTEM SWEREF 99 lat long ellh/
LATLONG DEG/
ELLIPSOID GRS 80/
PROJ GAUSS
G 13 30 0 DEG
0
150000
1
STOP /
GEOID SWEN08_RH2000 grid
Geoidhöjdsmodell för SWEREF 99,
bilinjär interpolation i grid SWEN08_RH2000.grd, geografiska lat long
Gridstorlek: 801x376
lat-min: 54° long-min: 10°
lat-max: 70° long-max: 25°
dlat: 0°.02 dlong: 0°.04
ELLIPSOID GRS 1980
GRIDSYSTEM SWEREF 99 lat long
HSYSTEM RH 2000
GRIDFIL SWEN08_RH2000.grd
GEOID SWEN08_RH70 grid
bilinjär interpolation i grid SWEN08_RH70.grd, geografiska lat long
ELLIPSOID GRS 1980
HSYSTEM RH 70
GRIDFIL SWEN08_RH70.GRD
- FME has a Workspace Parameter, Reprojection Engine, that may be set to either FME (CS-Map) or Esri. This transformer will override this parameter setting.
- The Reprojector provides similar functionality, and will use the default library (CS-Map or Esri) set in FME. It supports some Swedish coordinate systems, but will not use the Gtrans definitions or reprojection engine.
- To reproject coordinates stored as attribute values, consider using the GtransAttributeReprojector.
Coordinate System Support
Library |
FME (default) or Esri |
Library (External Links) |
Sweden |
Sweden |
Switzerland |
Features with geometry to be reprojected.
Features reprojected as specified in parameters.
Translation File |
Enter the path and filename of the desired Translation File. Files may be selected from the Gtrans Translation File gallery via the ellipsis button. |
Reverse Translation File |
If reprojecting rasters, the inverse Translation File must also be provided. Enter the path and filename. Files may be selected from the Gtrans Translation File gallery via the ellipsis button. |
Interpolation Type |
Select a method for interpolating reprojected cell values:
Cell Size |
Select a method for resizing cells:
Tolerance (cells) |
Sets the tolerance, in cells, for approximating reprojected cell locations. Using the default value of 0.0, every cell will be reprojected. If a value greater than 0.0 is specified, some cell locations will be approximated. The difference between an approximated cell location and the true cell location should be at most the tolerance value. For example, if a value of 0.5 is specified, each approximated cell location should be maximum one-half of a pixel away from its true location. Increasing the Tolerance value may improve performance. |
Dialog Options - Tables
Dependencies | Gtrans software and Translation Files, included with FME. |
Operating System Restrictions |
Windows only. |
Aliases | |
History |
Search for all results about the GtransReprojector on the FME Community.
Example contains data © OpenStreetMap contributors.
Keywords: SWEREF99 "National Land Survey of Sweden" Sweden
