CoordinateSystemSetter
Assigns a user-specified coordinate system to features, without modifying geometry or coordinates.
- Adding missing coordinate system designations
- Adding coordinate system designations when the feature's original format does not support them
- Fixing incorrect coordinate system designations
The CoordinateSystemSetter receives any feature and assigns a user-specified coordinate system to it. No geometry is modified, and data is not reprojected.
The coordinate system may be entered explicitly or set to an attribute value, user parameter, or conditional value.
If a feature already has a coordinate system assigned, it will be overwritten.
- If the coordinate system is not known, this transformer cannot be used to determine it. You will need to assess the units and extents of the coordinates to try to make a manual determination.
- Similarly, FME won’t carry out checks to ensure that any coordinate system selected is appropriate to the current data.
- You don’t need to use this to tag features before reprojecting them, as long as the reprojection is done via a transformer. Set the coordinate system in the chosen reprojection transformer’s Source Coordinate System parameter.
Dialog Options - Tables
Dependencies | None |
Aliases | |
History |
Search for all results about the CoordinateSystemSetter on the FME Community.
