RasterAspectCalculator
Calculates the aspect (direction of slope) for each cell of a raster. Aspect is measured in degrees from 0 to 360, clockwise from north.
- Calculating aspect on elevation rasters
The RasterAspectCalculator receives raster features, and calculates the aspect for each cell.
Aspect is calculated in degrees, from 0 to 360, clockwise from north. The calculation is done based on the values of surrounding cells (using a 3 cell x 3 cell window), and a choice of algorithms is available. Cells without data (Nodata) may be interpolated for calculation purposes. If an input band does not have a Nodata value, the output band Nodata value will be set to -1.
Aspect values are output on the same band they were calculated from, and the band is converted to Real64.
This transformer supports raster band selection. The RasterSelector can be used to modify this selection.
In this example, we will calculate the aspect of each cell in a DEM. Note that the elevation values are stored in Band 0 as integers (in meters).
The DEM is routed into a RasterAspectCalculator.
In the parameters dialog, we choose to interpolate Nodata, and use the Horn algorithm.
The output raster feature has new Band 0 values - the calculated aspect - and the band has been converted to a floating-point decimal interpretation type (real64).
Choosing a Raster Transformer
Working with Rasters
Enhances the features of a raster image. The RasterSharpener enhances the borders, lines, and curves while reducing noise in the flat areas of the raster image. |
Working with Bands
Working with Cells
Working with Palettes
Workflow Control
Vectors and Rasters
Raster features with cells to calculate aspect values on.
Raster features with calculated aspect values, stored in the same band they were provided in, converted to interpretation type real64.
Interpolate Nodata |
Calculate values at raster edges and near Nodata values. No: When any pixel in the 3x3 window used to calculate the aspect value is equal to Nodata, the output pixel will also be set to Nodata. If the input band does not have a Nodata value, the output band Nodata value will be set to -1. There will be a one pixel border around the edge of the raster set to the Nodata value. Yes: Values around the edge and near Nodata values will be estimated by interpolating missing values. Note that holes will not be filled in - cells that are Nodata in the input raster will remain Nodata in the output. |
Algorithm |
The algorithm used to calculate the aspect. Some analyses have suggested that Horn's formula is better suited to rougher terrain, whereas Zevenbergen & Thorne's formula is better for smooth terrain. |
Dialog Options - Tables
Search for all results about the RasterAspectCalculator on the FME Community.
