PathBuilder
Connects input linear (arcs and lines) features in the order they enter, forming path features.
If the end point of one input segment does not match the following segment's start point, geometry will be added to connect them in the following way. If the first segment is a line, then a point will be appended to it to extend it to the following segment's start point. If the first segment is an arc and the following segment is a line, then a point will be added to the beginning of the line to extend it to the first segment's end point. Otherwise, if both segments are arcs, then a two-point line will be inserted between these segments in the resulting path.
- To create the desired path, it may be necessary to use a Sorter to order the data correctly before it enters this transformer.
- It is possible to create self-intersecting paths with this transformer, which will not be rejected.
Group By |
The default behavior is to use the entire set of input features as the group. This option allows you to select attributes that define which groups to form – each set of features that have the same value for all of these attributes will be processed as an independent group. The feature being created is output whenever a Group By value changes. When this happens, the feature with the differing attribute is not added to the current output feature; instead, it begins the next feature to be output. If consecutive input segments are lines, they will not be combined into a single line in the output path; they will remain as separate segments. Also, if only one segment is input for a set of Group By values, the output will still be a path (containing that single segment). |
Complete Groups |
There are two typical reasons for using When Group Changes (Advanced) . The first is incoming data that is intended to be processed in groups (and is already so ordered). In this case, the structure dictates Group By usage - not performance considerations. The second possible reason is potential performance gains. Performance gains are most likely when the data is already sorted (or read using a SQL ORDER BY statement) since less work is required of FME. If the data needs ordering, it can be sorted in the workspace (though the added processing overhead may negate any gains). Sorting becomes more difficult according to the number of data streams. Multiple streams of data could be almost impossible to sort into the correct order, since all features matching a Group By value need to arrive before any features (of any feature type or dataset) belonging to the next group. In this case, using Group By with When All Features Received may be the equivalent and simpler approach. Note: Multiple feature types and features from multiple datasets will not generally naturally occur in the correct order. As with many scenarios, testing different approaches in your workspace with your data is the only definitive way to identify performance gains. |
Connect Z Mode |
Select a method. When viewed in 2D (ignoring Z), a path (which may define the border of a polygon) may appear to be closed as shown in the left figure below. This same path, when viewed in 3D, may appear to be open as shown in the right figure below.
Aggregate Handling |
Select a method for dealing with aggregate geometries:
Generate List |
Dialog Options - Tables
Search for all results about the PathBuilder on the FME Community.
