GeoRSSFeatureComposer
Constructs GeoRSS documents from the input features and stores them in the specified attribute for the features that are output by the GeoRSS port. The constructed GeoRSS document will be created according to the specified Geometry Format and Output Format, in the character set specified by the Output Character Set parameter.
For any given GeoRSS document, the metadata for the feed.
The entry features from the input GeoRSS document/feed.
The features containing the GeoRSS document in the attribute specified by the GeoRSS Attribute parameter.
Flush Attribute |
The GeoRSS document that is being constructed accumulates features until the value specified for the feature Flush Attribute. When this occurs, the newly received input feature is not part of the flushed document, but rather is part of the next document to be constructed. |
Output Format |
Choose the format of the XML feed that the GeoRSS writer will produce:
Geometry Format |
Choose the format of the output feed’s geometry extensions: GML, W3C, or Simple. |
Escape HTML Content |
This parameter determines how the writer handles HTML content. Select Yes to ensure that the writer will escape HTML content before outputting it. Select No to ensure that the writer will output the content unchanged. |
Output Character Set |
The character set encoding in which the output XML feed should be written. If no character set is specified, the feed will be written in the UTF-8 character set. If an invalid character set is specified, the translation will fail. |
Composed GeoRSS |
Name the attribute to contain the GeoRSS document. |
Dialog Options - Tables
Search for all results about the GeoRSSFeatureComposer on the FME Community.
