DecimalDegreesCalculator
Calculates a decimal degree value from separate degrees, minutes, and seconds (DMS) values, provided as attributes.
Calculating the decimal degree equivalent of latitude and longitude DMS (degrees, minutes, seconds) values.
The DecimalDegreesCalculator receives any feature with attributes containing valid degrees, minutes, and seconds values, and converts those to decimal degrees. The result is added to the output feature as an attribute.
If an invalid (for example, non-numeric) value is received, the translation will fail.
In this example, we have a dataset of world cities, with latitude and longitude coordinates stored as attributes, in degrees, minutes, and seconds.
We want to convert these into decimal degree values, and will start with latitude.
The features are routed into a DecimalDegreesCalculator.
In the parameters dialog, Degrees, Minutes, and Seconds Attribute(s) are set to the corresponding latitude attributes - lat_degrees, lat_minutes, and lat_seconds. The default output attribute name is prefixed with lat_.
The output features now have a lat_decimal_degrees attribute, containing the calculated decimal degree value.
If degrees, minutes, and seconds are concatenated into a single string, they can be extracted with a StringSearcher or AttributeManager with string functions.
Features with degrees, minutes, and seconds values stored as individual attributes.
Features with decimal degree values added as specified in parameters.
Degrees Attribute |
Specify the source attribute containing the degrees value. |
Minutes Attribute |
Specify the source attribute containing the minutes value. |
Seconds Attribute |
Specify the source attribute containing the seconds value. |
Output Degrees |
Name the attribute to contain the resulting decimal degrees values. |
Dialog Options - Tables
Search for all results about the DecimalDegreesCalculator on the FME Community.
