CenterlineReplacer
Replaces area geometries with their centerlines or straight skeletons. This transformer works best with long, narrow areas.
Example
- Input areas must not self-cross and the region covered by the area must be connected.
- Z coordinates are ignored by this transformer. All centerlines are 2D.
When combined with the Tester, this transformer enables FME to perform area generalization operations.
The centerline of the input feature will be output via this port. If the input feature is an aggregate, at least one part was successfully processed, and the algorithm fails to generate a centerline for another part, that part will be left unchanged.
Features that cannot be replaced by their centerline will be output via this port.
INVALID_GEOMETRY
INVALID_POLYGON
INVALID_ELLIPSE
INVALID_DONUT
Mode |
Centerline: A line is returned that approximates the shape of the original input, and is roughly equidistant to the boundaries on either side.
Straight Skeleton: Every edge segment of the input area’s boundary is moved inwards at a constant speed -- the intersection of the moving segments is returned as the “Straight Skeleton.” Note: this mode returns branches that will touch the edges of the original area.
Note: In the straight skeleton mode, the algorithm may take a long time to run on large or complex input features. |
Dialog Options - Tables
Search for all results about the CenterlineReplacer on the FME Community.
Keywords: abstraction simplification simplify centerline centreline CentreLineReplacer
