BoundingBoxReplacer
Replaces the geometry of the feature with either its two-dimensional bounding box, its two-dimensional minimum oriented bounding box, or its three-dimensional bounding cube.
If a feature’s bounding box has zero area, it will become a line or a point.
- To accumulate the bounding box of a number of features, use the BoundingBoxAccumulator.
- To retrieve the bounds of a feature into attributes, use the BoundsExtractor.
- To replace the geometry of a feature with a box whose values come from attributes, use the 2DBoxReplacer.
- Point Clouds: the BoundingBoxReplacer does not consider individual points within a point cloud feature. To generate a 2D Oriented Bounding Box from point cloud points, use a PointCloudToPointCoercer prior to the BoundingBoxReplacer, setting the Output Geometry parameter to Single Multipoint.
Replace With |
Select the type of bounding box to create:
Long Side Length |
Name the attribute to contain the calculated length of the longest side of the bounding box or cube. |
Short Side Length |
Name the attribute to contain the calculated length of the shortest side of the bounding box or cube. |
Long Side Angle |
If Replace With is 2D Oriented Bounding Box, name the attribute to contain the angle of the longest side of the oriented bounding box. This value will be between 0 and 180 degrees. It is measured counter-clockwise from the positive X axis. |
Dialog Options - Tables
Search for all results about the BoundingBoxReplacer on the FME Community.
Keywords: MBR "minimum bounding rectangle" neatline "envelope oriented" "bounding box"
