3DForcer
Adds z coordinates to features, creating or modifying 3D geometry.
Converting 2D geometry to 3D
Updating z coordinates with new values
The 3DForcer receives any geometry type and adds z coordinate values, converting 2D features to 3D.
Z values may be supplied by an attribute, expression, or user parameter. Existing z values may be preserved or overwritten. If a non-numeric value is provided, features will output via the <Rejected> port.
Z values should generally be in the same units as the x and y coordinates. Features with latitude/longitude coordinate systems may need to be reprojected.
Raster features, including digital elevation models, will pass through unchanged.
In this example, we have a set of 2D building footprint polygons, which have a number of attributes including base elevation and building height.
We want to turn these into 3D objects. Note that the coordinate system is UTM, with ground units in meters.
This will take two steps:
The features are routed into a 3DForcer to convert them from 2D to 3D.
The 3D features are extruded based on the building height to create objects.
In the parameters dialog of the 3DForcer, Elevation is set to the value of the baseelev_m attribute, which contains the elevation of the base of the structure.
Note that the units - meters - match the ground units of the coordinate system. If they did not match (if the coordinate system was latitude/longitude, for example) the features would need to be reprojected before using the 3DForcer.
The output features are now 3D, with z coordinates obtained from the baseelev_m attribute. Though they now have an elevation, they have a height of zero (0).
The features are passed on to an Extruder, where they are extruded to their height above ground.
This transformer applies the same z value to all vertices of a feature. To interpolate vertex elevation values from another dataset, use the SurfaceDraper.
To apply elevations from an underlying digital elevation model, use the PointOnRasterValueExtractor.
Features with z coordinates added as specified in parameters.
Features receiving invalid z coordinate values, such as non-numerical values, will be rejected and output via this port.
Elevation |
Supply an elevation value by entering it, or provide an attribute name, expression, or user parameter. |
Preserve Existing Z Values |
Specify how features with existing z values should be treated:
Dialog Options - Tables
| Aliases | ElevationSetter |
Search for all results about the 3DForcer on the FME Community.
