Using Web Connections
Many processes in FME Desktop require you to connect and authenticate to a web service in order to use them. For example, when you use an HTTPCaller transformer, you may need to authenticate to a web service, such as Google BigQuery. Similarly, if you want to connect to an FME Server, you must specify a set of connection parameters. Web connections provide a convenient and secure way to store and reuse these connection parameters. Each time you need to specify the same connection parameters, you can use the connection, rather than re-entering the parameters. If the connection parameters change, you can edit them in one place, rather than in each workspace that uses the connection.
Managing Web Services
FME Desktop must be registered to use the web services to which you want to connect. Although many of the most common web services are already registered in FME for testing purposes, we recommend defining your own for production purposes. Use Tools > FME Options > Web Connections to manage web services. For more information, see Managing Web Services.
Tip: To create a connection to an FME Server that authorizes as a user imported from Microsoft Azure Active Directory, you must define a Microsoft Azure Active Directory web service. For more information, see see Managing Web Services.
Adding Web Connections
It is usually more convenient to add a web connection at the time you are using one in a workspace or connecting to FME Server (see below). However, you can also add a web connection in Tools > FME Options > Web Connections, and use it later in a workspace.
 Expand for details
Expand for details
                                                    You can use an existing web connection, or define a new one, in a Transformer Parameters, Add Reader, or Add Writer dialog.
WARNING: For production purposes, we recommend specifying user-defined web services, rather than the pre-registered services already provided. For more information, see Managing Web Services.
Visibility: This field applies only if Connection Storage, as specified in Tools > FME Options > Default Paths, is a shared location visible to multiple users. Specify whether the connection is available only to yourself, or to any user of the database (Public). For more information, click Help from the Default Paths window under Tools > FME Options.
Note: The following characters are not allowed in connection names: ^ \ / : * ? " < > | & = ' + % #
Using Web Connections to Connect to FME Server
 Expand for details
Expand for details
                                                    To connect to FME Server, you can use a web connection that specifies the FME Server web service. You can use an existing connection, or define a new one, in the publish or download wizard.
In the Connect to an FME Server dialog, specify the Connection name.
To create a new connection and use it right away, select Add Web Connection.
In the FME Server Connection dialog, specify:
- Web Service: FME Server
- Server URL: The URL of the FME Server. For more information, see Accessing the Web User Interface in the FME Server documentation.
- Authentication: The method for authenticating with FME Server.- Basic: Authenticate with the specified User Name and Password of an FME Server user.
- Azure AD: Authenticate with the Azure Active Directory credentials of an FME Server user.
- Windows Credentials: Authenticate with Integrated Windows Authentication ("single sign-on"). You must be logged in to Windows with credentials that are imported to FME Server from a Windows Active Directory connection and are enabled for single sign-on. For more information, see Configuring Integrated Windows Authentication in the FME Server documentation.
- Azure AD Connection: If Azure AD is specified above, specify the Azure AD web connection to use for this connection. For more information, see Create an FME Server Azure Active Directory Web Connection in FME Desktop.
Reusing a Web Connection
Note: If you did not create a connection, it may not be available for you to use unless its visibility is updated. For more information, see To change the visibility of a web connection.
