LocalCoordinateSystemSetter
Assigns a specified local coordinate system to features, without modifying geometry or coordinates.
- Adding missing local coordinate systems
- Adding local coordinate systems when the features’ original format does not support them.
- Fixing incorrect local coordinate systems
The LocalCoordinateSystemSetter receives any feature and assigns a specified local coordinate system to it. No geometry is modified, and data is not reprojected.
The local coordinate system may be either Equidistant (AZMED) or Equal Area (AZMEA), and a choice of ground units is provided.
The local coordinate system is mapped to a true coordinate system by selecting that coordinate system and entering the X and Y coordinates that match 0,0 in the local coordinate system
Note that Z coordinates are not considered, and so areas or distances are best preserved for geometry at an ellipsoid height of zero (0) meters.
If a feature already has a coordinate system assigned (local or otherwise), it will be overwritten.
- If ground units need adjustment to match the coordinate system, consider using a Scaler prior to this transformer.
Dialog Options - Tables
Dependencies | None |
Aliases | |
History |
Search for all results about the LocalCoordinateSystemSetter on the FME Community.
