Scaler
Scales x, y, and/or z coordinate values to resize geometry.
Scaling z values for emphasis or de-emphasis
Scaling z values when vertical and horizontal units are mismatched
Georeferencing
Sizing objects or labels
Mirroring objects
Changing units
The Scaler receives features with any type of geometry and applies a multiplier to their coordinates, resizing the features relative to either their center or the origin of their coordinate system.
X, y and/or z coordinates are multiplied by the provided X, Y, and Z Scale Factors. A scale factor of one (1
) implies no change to a coordinate.
The origin for scaling may be either 0,0 in the feature’s own coordinate system, or the center of the feature itself.
When using the 0,0 origin, if the object being scaled is not on or near the 0,0 point of the coordinate system (as is usually the case with georeferenced data), using the Scaler will also introduce a shift.
When using the Center Point origin, each individual feature will be scaled around its own center, not the center of the dataset’s extents.
Additional parameters are provided for type-specific scaling, including text, raster, and point cloud. This transformer supports raster band and palette selection. The RasterSelector can be used to modify selection.
- The Aggregator and Deaggregator may be useful for scaling around a dataset’s center.
- Reprojecting to a local coordinate system may also be useful - see the CommonLocalReprojector and Reprojector (to local coordinate systems).
Dialog Options - Tables
Dependencies | None |
Aliases | |
History |
Search for all results about the Scaler on the FME Community.
