GoogleDriveConnector
Accesses the Google Drive file storage service to upload, download, or delete files and folders or list the contents of a folder from a Google Drive account.
Jump to Configuration
  • Manage datasets on Google Drive by uploading, downloading, and deleting files and folders
  • Transfer a file's contents (such as XML, point cloud, or raster) into or out of an attribute in FME
  • Read downloaded Google Drive data using the FeatureReader, or upload data written by the FeatureWriter to Google Drive
  • Retrieve file and folder names, paths, links and other information from Google Drive to use elsewhere in a workspace.
The GoogleDriveConnector uses your Google Drive account credentials (either via a previously defined FME web connection, or by setting up a new FME web connection right from the transformer) to access the file storage service.
Depending on your choice of actions, it will upload or download files, folders, and attributes; list information from the service; or delete items from the service. On uploads, link attributes are added to the output features. On List actions, links and file/folder information are added as attributes.
  • This transformer cannot be used to directly move or copy files between different Google Drive locations. However, multiple GoogleDriveConnectors can be used to accomplish these tasks.
  • The FeatureReader can access Google Drive directly (without using the GoogleDriveConnector), however, a local copy of the dataset will not be created.
The remaining parameters available depend on the value of the Request > Google Drive Action parameter. Parameters for each Google Drive Action are detailed below.
Dialog Options - Tables
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies Google Drive account
Aliases
History Released FME 2017.0
Search for all results about the GoogleDriveConnector on the FME Community.
