| Database Connection Created | Triggered whenever a new database connection is created. |
        | Key | Description |
        | databaseConnection.event | Database Connection action: Create |
        | databaseConnection.name | Database Connection name |
        | databaseConnection.type | Database Connection type |
        | event.id | Event ID |
        | source | Event type |
        | systemEvent.description | System Event description |
        | systemEvent.title | System Event title |
        | time | Event time |
        | user | Performed by |  |
        | Database Connection Removed | Triggered whenever a database connection is removed. |
        | Key | Description |
        | databaseConnection.event | Database Connection action: Remove |
        | time | Event time |
        | Database Connection Updated | Triggered whenever database connection details are updated. |
        | Key | Description |
        | databaseConnection.event | Database Connection action: Update |
        | time | Event time |
        | Error Message Logged | Triggered whenever an error message is logged to fmeserver.log. |
        | Key | Description |
        | message | Message content |
        | time | Event time |  |
        | License About to Expire | Triggered when an FME Server license is about to expire. Note: Applies to both standard and Dynamic Engine (CPU Usage) licenses. |
        | Key | Description |
        | Login Failed | Triggered whenever a user failed to log in to the Web User Interface. |
        | Key | Description |
        | time | Event time |
        | Login Successful | Triggered whenever a user successfully logs in to the Web User Interface. |
        | Key | Description |
        | time | Event time |
        | Low Credits | Triggered whenever remaining credit hours on Dynamic Engines (CPU Usage) fall below a specified amount. |
        | Key | Description |
        | Project Exported | Triggered whenever a project is exported from the system. |
        | Key | Description |
        | migration.id | Task ID |
        | migration.options | Migration options |
        | migration.status | Status |
        | time | Event time |
        | Project Imported | Triggered whenever a project is imported to the system. |
        | Key | Description |
        | time | Event time |
        | Repository Created | Triggered whenever a new repository is created. |
        | Key | Description |
        | repository.event | Repository action: Create |
        | repository.path | Repository/Item name |
        | time | Event time |
        | Repository Item Downloaded | Triggered whenever an item is downloaded from a repository. |
        | Key | Description |
        | repository.event | Repository action: Download |
        | time | Event time |
        | Repository Item Published | Triggered whenever an item is published to a repository. |
        | Key | Description |
        | repository.event | Repository action: Publish |
        | time | Event time |
        | Repository Item Removed | Triggered whenever an item is removed from a repository. |
        | Key | Description |
        | repository.event | Repository action: Remove |
        | time | Event time |
        | Repository Item Republished | triggered whenever an item is republished to a repository. |
        | Key | Description |
        | time | Event time |
        | Repository Metadata Updated | Triggered whenever repository details are updated. |
        | Key | Description |
        | time | Event time |
        | Repository Removed | Triggered whenever a repository is removed. |
        | Key | Description |
        | time | Event time |
        | System Backup Completed | Triggered whenever a system backup has completed. |
        | Key | Description |
        | time | Event time |
        | System Restore Completed | Triggered whenever a system restore has completed. |
        | Key | Description |
        | time | Event time |
        | System Started | Triggered when the system is started and ready to process jobs. FME Server is ready to run jobs when the FME Server Core, FME Notifier, FME Relayer, and FME Server Job Queue processes are started, healthy, and running. |
        | Key | Description |
        | User Created | Triggered whenever a new user is created. |
        | Key | Description |
        | account.email | User email |
        | account.enabled | User enabled |
        | account.event | User action: Create |
        | account.fullName | User full name |
        | account.name | User name |
        | account.roles | User roles |
        | acccount.sharingEnabled | User sharing enabled |
        | time | Event time |
        | User Metadata Updated | Triggered whenever user details are updated. |
        | Key | Description |
        | account.event | User action: Update |
        | time | Event time |
        | User Removed | Triggered whenever a user is removed. |
        | Key | Description |
        | account.event | User action: Remove |
        | time | Event time |
        | Warning Message Logged | Triggered whenever a warning message is logged to fmeserver.log. |
        | Key | Description |
