Log a Message
The Log a Message action logs all message it receives to the Automation log for the workflow.
Tip: To view the automation log, click Go to Logs under Log Details. The Automation Log page filters to display only logs that were created explicitly from Log a Message actions.
Note: See also Working with Parameters in Automations Workflows.
  • Formatted Message: Specify a message to append to the beginning of the log.
