SpatialFilter
Filters point, line, area, and text features based on spatial relationships. Each input Candidate feature is compared against all Filter features, based on the given spatial tests to meet. Features that pass any or all tests are output through the Passed port; all other features are output through the Failed port.
Jump to Configuration
  • Routing features, depending on whether a defined spatial relationship is true or false
  • Performing quality control on a dataset by checking for expected spatial relationships with another dataset
  • Performing a spatial join to transfer attributes from one feature to another based on their spatial relationship
The SpatialFilter compares two sets of features to see if their spatial relationships meet selected test conditions. The features being tested (Candidate features) are identified as having Passed or Failed the test.
For example, if you have a roads dataset (lines), and wanted to extract all the roads that passed through parks (polygons), you would direct the roads into the Candidate input port, and the parks into the Filter input port.
By selecting the test conditions Filter OGC-Intersects Candidate and Filter OGC-Contains Candidate, any road lines that fall within the parks or intersect the parks would be output via the Passed output port, and the remainder would exit through the Failed output port. You could simultaneously extract an attribute from the park polygon – park name, for example – and add it to the line feature.
  • See Spatial Relations Defined for more information on spatial predicates and an illustration of spatial relationships.
  • Spatial relations are based on the OGC specification and so are undefined for geometries that are not OGC valid.
  • Aggregates are accepted by a subset of predicates, but should be used with care. See Spatial Relations Defined for more information.
Dialog Options - Tables
Processing Behavior
Group-Based
Feature Holding
Yes
Dependencies
Aliases
History
Search for all results about the SpatialFilter on the FME Community.
