AreaOnAreaOverlayer
Performs an area-on-area overlay (intersection of polygons) so that all input areas are intersected against each other and resultant area features are created and output. The resultant areas can accumulate attribute from any overlapping polygons.
Jump to Configuration
  • Deconstructing overlapping polygons to produce the intersections and differences
  • Comparing multiple datasets for area overlaps
  • Performing area calculations based on overlapping area data
The AreaOnAreaOverlayer takes in area features. All polygons are considered against each other, and where they overlap, new polygons are created that represent both the overlapping area and the original areas with the overlap removed.
The new polygons can retain attributes from all original relevant features (performing a spatial join), and a count of the number of overlaps encountered during the overlay. This count starts at 1 for all features, as they are considered to overlap themselves.
Aggregates can either be deaggregated before processing or rejected.
Dialog Options - Tables
Processing Behavior
Group-Based
Feature Holding
Yes
Dependencies
Aliases
History
Search for all results about the AreaOnAreaOverlayer on the FME Community.
