MGRSToLatLongConverter
Determining the center point of the area represented by a standard MGRS code.
The MGRSToLatLongConverter accepts any feature. The user specifies an attribute, expression, or user parameter containing a valid MGRS Code, along with the Ellipsoid and appropriate Lettering Type.
The coordinates of the center point of the described area are added as attribute values. The size of the area (and so the position of the center point) depends on the precision of the MGRS code, ranging from 1 meter square to 100 km square. See LatLongToMGRSConverter for more information.
For more information on the MGRS, see Military Grid Reference System.
This transformer does not create geometry. To create points from the coordinates, consider using a VertexCreator.
Dialog Options - Tables
Dependencies | None |
Aliases | |
History |
Search for all results about the MGRSToLatLongConverter on the FME Community.
