LatLongToMGRSConverter
Calculates a Military Grid Reference System (MGRS) code based on latitude and longitude values.
Jump to Configuration
  • Determining which standard MGRS boundary contains a given point.
The LatLongToMGRSConverter accepts any feature. The user specifies attributes, expressions, or user parameters containing latitude and longitude coordinates, along with the Ellipsoid and desired Lettering Type.
The standard MGRS code is generated to the specified Precision, and stored as an attribute.
Precision is an integer from 0 to 5 (inclusive). A precision of 5 locates a point within a 1-meter square and precision of 0 locates a point within 100-km square.
Dialog Options - Tables
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases
History
Search for all results about the LatLongToMGRSConverter on the FME Community.
